Question about HP Deskjet F340 All-In-One Printer
HPF340 My printer is fairly new, I replaced the cartridge and still an E light and red lights flash on it. The jobs on the printing screen just keep stopping as well
  • 181 Answers
I would say the most likely cause of the issue is either that the printer is no longer functioning or that it is experiencing power issues. Make sure that the printer is plugged in directly to the wall and not into a surge protector or a power strip. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all.
Leave the printer on and then unplug and wait for 30 seconds and then plug in directly to the wall if it isn't already. Try a copy and see if that works.
Posted on Feb 28, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have an HP Photosmart 7260 printer that my cousin gave to me used so I have no manual. I've replaced both ink cartridges and am trying to print. When I send the print job, a red light begins to flash...
Can you see any symbol when the red light flashes? or any message pops up on your computer? Since your problem's description isn't very specific, I am unable to assume myself. If cartridges are replaced with new ones and the problem persists, it's possible that there's paper jam or carriage jam or contacts on the printer is bad/dirty. While the machine is On, lift up the front access door and try moving the carriage manually. Please follow this LINK to clean the contacts.
Please post back with more specific details so that I can help you better. Good Luck.
Feb 18, 2011 | HP PhotoSmart 7260 InkJet Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
All the lights keep flashing --won't print!
I removed the black ink cartridge that was REFILLED at a popular retail outfit and replaced it with a remanufactured one I bought on the web. As soon as I closed the lid, the flashing stopped and it has been working GREAT ever since. Many postings had already recommended the changing to a "new cartridge" to remedy this flashing lights and "pen failure."
Jan 14, 2010 | HP Photosmart 2410 All-In-One InkJet...
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Error light
You have installed a refilled cartridge without changing the chip on the bottom of the cartridge. Your error light will flash and also upon starting your computer, you will probably get an error screen saying the bi-directional connection is disabled. The printer should still work, but will be slow because it recycles between each page. My error light has been flashing for some time, but when I send a document to the printer, the error light stops flashing and the printer prints. After the print job is done, the error light resumes flashing. The only real solution is to replace the chip on the toner cartridge with a new one.
Dec 18, 2007 | Konica Minolta PagePro 1350W Laser Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
