Question about Pioneer VSX-D812 Receiver
Proper input for TV audio signal
Recently purchased 37-in. Magnavox LCD TV, primarily to watch DVD's.
Can't seem to get DVD audio feed to play thru speakers wired to the Pioneer. Have purchased (Best buy) and installed cable I was directed to purchase. Cable leaves ("OUT") TV from port specified in TV User Manual, and enters Pioneer at "DVD" in port......what is the problem?
  • 4 Answers
Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
Posted on Feb 18, 2008
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
We have a lg, lcd tv.model#37-LD450, we cannot get our DVD player connected so that it plays, any help would be appreciated, owners manual on a dvd and no use
Your dvd will have a scart socket or a hdmi or other socket, ( check manual), connect lead from dvd to tv, output from dvd to input on tv, from one of these ,on your tv remote select the button that changes the av select , that means the button that tells tv that you want to watch signal from dvd ,( or other input devices) ie sky video camera etc it may be av1 av2 av3, you should get a picture on one of these,
hope this helps
pete
Nov 15, 2010 | Televison & Video
Unable 2 watch dishtv in Benq LCD SD3731 with DVD cbl plugged in
The S_Video connection has precedence (most likely named AV1) over the RCA/composite one (better image quality - usually named AV2) so it will be automatically selected. If you want to view thru AV2 input you will have to select it manually every time you want it.
Jan 07, 2010 | Televison & Video
Dvd recorder set up
there are some tv (sony) that you can get video and audio out from the tv and then is simple task to record what is in the tv. But maybe you don't have that option.
the second idea is this:
Think in the signal that comes from the box as a river and you need to divide this river (signal) before gets to the tv, so feeding the signal to the tv and the set you use to record then you have the option to record and watch the tv as regular; only task to do now is to monitor the recording in the input where you assigned for the dvd recorder. i hope is clear the idea to you!
Apr 14, 2009 | Televison & Video
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Dvd input
I don't know this model of TV in particular. I can give you a generic answer that should allow you to figure this out.
Check the options for your TV set. See if there are the connectors at the rear side for an external audio and video input that is compatible to your DVD player. This would be an external video audio input option. If there is and you do not have a switch for it, then you need the original factory remote contol. Many of the universal remotes lack the full features of the products.
If your TV set does not have the option for external video and audio, one work around is to purchase an audio video RF TV modulator. Many of the stores that sell TV options usually carry these devices. You can then add a CATV 2 way cable switch to switch between the modulator and your cable service or antenna. You will have to purchase the additional necessary interconnect cables.
On the input of the RF TV modulator you would connect the DVD player. The quality will not be very good, but at least you will be able to watch the DVD player on your TV set.
Once you figure everything out, bring a print of this email to the dealer. When he looks at all this he should know exactly what you require.
Jerry G.
Nov 01, 2008 | Philips Magnavox 27MS343S 27" TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Pioneer VSX-D812 Receiver Logo
106 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
