Question about Polaroid FCM-0710 7 in. Television
How to auto program -
Trying to have Dish hooked up and can't auto program
    President:
  • 1,944 Answers
Here is the user manual if you don't have it. Might help you....
http://www.polaroid.com/media/com/pdfs/products_internal/FCM-0710_usermanual_v2_m56577569830533383.pdf
Posted on Feb 16, 2008
  • 770 Answers
If you are connecting dish Network to the TV you will need to go thru a receiver first.. then whatever input you connect the receiver to then you will be able to get the channels on that setting.. If that is what you are trying to do?
  • Gary Davd
    Gary Davd Feb 16, 2008
    One other thing if it is Dishnetwork you are talking about you only need the TV on channel # 3 or # 4 based on what you set the switch on the back of the receiver(this is if you are using the RG6 coax cable to connect it)
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
I am trying to hook up dish network and need the code for remote control programming
Hello there! This is Becki Barned with DISH Network Customer Service. You may have gotten the remote programmed already, but I included a link to our website below to help program your remote. I hope this helps either now, or in the future!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
Dec 28, 2010 | Curtis LCDVD2223AC 22 in. TV
How do I enter the dish network code to hook it up to my tv?
Try this link it will give you programming codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
Nov 30, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
I have a philips TV that is digital 27PT8302/37 32PT8302/37 and I cannot get any digital channels I also have a winegard amplified Antenna, and I am connected to dish, All was working well and now after...
you should have a seperate tuner [marked digital] to hook up the antenna then tell menue where to look and reprogram
you could use a box and use channel 3 or 4
i assume you have the dish hooked to auxilary in
Sep 01, 2009 | Philips 27PT8302 27" TV
Unhooked the TV,took it to another room, hooked it up, just fuzz
Make sure the cable you now have hooked up to TV is actually hooked up to the dish. If you're sure it is then take the TV back to original location and hook it back up. If it works in that location you have a bad cable. If it still doesn't work it's the TV. The only other thing I can suggest is that some TV's must autotune before a picture can be shown. If you're sure you have a ggod signal go to the TV menu and do an auto tune or auto search. The TV will then go thru all the different possibilities looking for signals. Once it has completed the search it will then give you a picture. You can then go and add/delete channels and set it up however you want.
Jan 24, 2009 | GE 32GT660 32" TV
Auto format Polaroid Dolby under the cabinet tv/dvd
you have posted this twice plz see my comments on your other post for this problem..
Feb 16, 2008 | Televison & Video
Polaroid FCM-0710 7 in. Television Logo
126 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
