Question about HP Officejet 9110 All-In-One InkJet Printer
Line Printing to hp office jet9110
My unit is not telling me I am out of ink, But my pages are comming out with pink lines through them. What do I need to do?
Thank you
  • npirr Feb 18, 2008
    How do you change the print heads is this not part of the ink cartridges?
I have this same problem, I have pink lines going through everything that I try to print in color. When I print in black and white, everything works fine. The blue and yellow ink cartridges aren't empty, so I'm not sure what the problem is. Any suggestions?
Posted on Jun 25, 2008
You might need to change the print heads...worked for me.
Posted on Feb 18, 2008
There is a 3 cm line through my page from top to bottom that is blank when printing
Hi it is usually the fuser that causes this problem You will have to replace it.
Sep 27, 2016 | CISinks Continuous Ink Supply System] for...
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
A few days ago my printer began printing about 3 lines, skipping 2 lines and printed the bottom half of the next line - it printed the whole page in this manner. Someone at Office Max, where I bought the...
Hi bkoll2,
When your printer seems to be skipping lines it's mostly because your printhead needs cleaning. This cleaning must be done ONLY by using the printer utility on the PC. If you cleaned them manually you might have damaged the ink cartridges or the printer itself. Try replacing the ink cartridges and trying again.
If you're still having issues check this detailed guide: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612
Otherwise contact tech support.
Hope this helped.
-Luchen
Mar 10, 2011 | HP Officejet Pro L7680 All-In-One Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
A pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
Aug 12, 2008 | HP Color LaserJet 2600n Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
248 people viewed this question
Seeker5211
Seeker5211
