Question about Kenmore 16879 Built-in Dishwasher
Kenmore 16879 built in just stopped - no power at all now
  • I checked the breaker - all is fine.
  • no lights come on when you push the setting buttons
  • on the last wash, there was about an inch of water that did not drain
  • some soap was left in the dispenser after the wash cycle finished
  • 770 Answers
Open the bottom panel and check the eclect box see if you find any burnt off wire nuts if all is ok there you need to check the door switch.. TURN OFF THE BREAKER FIRST!
Posted on Feb 16, 2008
Dishwasher stopped working mid-cycle
Make sure you have power to the unit. Check the circuit breaker.
May 15, 2014 | KitchenAid 24 in. KUDI01FLSS Stainless...
Power to Front Control Panel
YOU DEFINITLY HAVE POWER COMING TO THE UNIT?IS THERE A TRANSFORMER?IF YOU HAVE THE CORRECT VOLTAGE AND THE KEYSWITCH (TOUCH PAD)PLUGS INTO THE BOARD YOU REPLACED THE KEYSWITCH IS BAD.HOW DID THE PROBLEM START?
Aug 28, 2007 | Kenmore 16879 Built-in Dishwasher
Control panel buttons no longer work.
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Aug 01, 2017 | Kenmore 13742 / 13744 / 13749 Built-in...
The heating coil on bottom of my Kenmore DW 16879 broke. Can I repair it myself or do I need a repairman? Where can I buy the coil (heating element)?
They are not that hard to replace. but be sure to turn it off at the circuit breaker, or if it plugs in under the sink, unplug it before servicing it.
there are many sources of parts, http://midwestapplianceparts.com/ is one online. there should be a few in your local area as well.
You will need to remove the DW from under the cabinet and remove a panel to get to the connections.
Not an overwelming job, but will take a few hours if you have never done it... BTW, be carefull of the water supply line... as in do not break it!!! you will want to turn it off before moving the DW and insure it is not leaking after you reinstall the DW.
Peace
Feb 27, 2010 | Kenmore 16879 Built-in Dishwasher
Same problem!
sounds like the main control board needs to e replaced this is the most likely problem
Sep 16, 2009 | Kenmore 15129 Built-in Dishwasher
Dishwasher stopped. no lights, no nothing
My Kenmore just did the same thing, I verified power to the unit.
Jun 26, 2009 | Bosch SHU3306UC Built-in Dishwasher
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Kenmore model 665.15912001dishwasher
The controller board is burned out...common problem on this model. Only way to fix is to replace with a new one. Cost of part is about $130.
Apr 17, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher
Check that the pump spins freely.
Aug 29, 2007 | Kenmore 16879 Built-in Dishwasher
Kenmore 16879 Built-in Dishwasher Logo
154 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
