Question about LG L1717S-BN 17" LCD Monitor
Flatron l1717s blank screen
Helloo i was working on my pc fine, and then all of a sudden i turn around and the screen is black!! the green power button is flashing tho. i have tried switching on and off ... but nothing. when it turns on it looks lke its going to work cos it brings  up the window screen and then goes back to black.
  • 1 more comment
  • meglan Feb 17, 2008
    i wish. we checked al that and left computor off for a fll 24 hours!
  • glenlouder Oct 08, 2008
    yup same thing here :(
  • Anonymous Oct 21, 2008
    no drivers? help!
There is one thing you can try. I have a internet cafe and I had 2 LG L1717S monitors that did the same, I went into the monitor screen settings and restored to factory settings. That sorted that problem out for me.
Posted on Oct 10, 2008
I have the same problem! I've tried everything (I shut down the pc - unplug the monitor - change monitor's power and still nothing!!!) when in start doing that thing I could fix it just turnning of the monitor a few times! do you have any idea how i can fix it????(don't tell me by buying another monitor...p)thaks!!!
Posted on Sep 25, 2008
  • 33 Answers
Common cause of this is the VGA or DVI connectors not screwed on tight on either the back of the PC or the back of the monitor.
Also try removing power by unplugging for 30 seconds, sometimes that will reset things.
Posted on Feb 16, 2008
Update drive flatron l1717s
Drivers are available from the manufacturer's website. Click the link below and click the "Drivers & Software" tab, then download the file "L1717S.zip"
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=L1717S-SN&initialTab=documents&targetPage=support-product-profile
Jun 15, 2011 | LG FLATRON L1717S 17" LCD Monitor
Why is it when my flatron monitor is plugged in to my laptop, the flatron screen reads "power saver on" and then turns off???
Have you pressed the key to allow VGA output....it is usually a combination of "Fn" + an "F" key
(at the top of the keyboard).
"Fn" is usually found near the left "Ctrl" or "Shift" keys. The F key has picture of a monitor or "LCD" on it
May 18, 2011 | LG L1717S-BN 17" LCD Monitor
My LG Flatron L1520B monitor "Locked/Unlocked"
press the power button for 1 mn and release it if still the same problem change your inverter board.
Oct 28, 2010 | LG FLATRON L1717S 17" LCD Monitor
LG Flatron LX151 i have it, and my problem is it cant open or power on, when i plugging it into AC it just turning the blue power indicator for a second and nothing next
Which will be cheaper:
* paying a technician $50 to $75 for labour/parts to fix it?
* paying $50 to $100 to buy a new 17-inch LCD monitor?
Jul 31, 2010 | LG FLATRON L1717S 17" LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
LG Flatron L1717S Won't Turn On
neaverules, The first board you will want to inspect very closely (and I mean very closely) will be the SMPS board. you know the one that has the AC line cord plugged into it. Beg,Borrow,Steal the biggest magnifying glass, or 10x-20x inspection microscope you can get your hands on!!! Here is what you will be looking for. On the bottom side of the circuit board check for bad solder connections over the whole board. look for solder joints that appear to be "frosted" "dull" as opposed to shiney and bright like a sliver ring in the jewelry shop. Next inspect for very fine almost invisible "circular" hairline fractures around the "Through Hole" leads of the larger and heavier components. Then move on to the 1, 2, 3watt resistors checking them also. Pay attention to areas of board that have been discolored. Also check all of the Electrolytic Filter Capacitors. Make sure that the tops are still FLAT. BAD (failed) caps will be swollen on top. ( DOMED). The before mentioned hairline fractures are caused by thermal and /or vibration stress. Get back to me with results. I'm louie12fix on fixya or lmistyrel @aol.com BYE for now.
Apr 05, 2009 | LG L1717S-BN 17" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
LG L1717S-BN 17" LCD Monitor Logo
826 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
