the oven went into self clean mode for 2 hours> it worked flawlessly. after the self cleaning mode and cool down, the oven will not work. Broil convection bake will not work in any mode. the time works. the touch panel works. i shut it off at the breaker tp see if it would clear and then reset the clock. any tricks that i can try?
Comment by dweck, posted on Feb 16, 2008
Comment by dweck, posted on Feb 24, 2008
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 30, 2008
I tried every thing that dweck tried. I would like to try to reset myself. does anyone have step by step instructions?
sue
Comment by Guest, posted on May 17, 2008
Dacor self-cleaning oven. Set to self-clean 2hrs. Thereafter it won't work. Heats to 125 preheat, but no further.
Clarification Request
by Master_Tech, posted on Feb 16, 2008
I will get back to on this
no real tricks here i will need to pull the manual on it so i can traces the wires to the elements... from what you described the ctrl panel is ok the clicks you are hearing are from the board they are relays closing to send pwr to the heating elements and fans but what i dont know is what is inline before the pwr get there
No Codes came up on the unit ????Does the keypad beep while you are trying to press the funtions??
did the door unlatch??
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Dacor ECS127 Epicure Stainless Steel
Email this problem
Can you Help with these Ovens problems?
oven displays "fo"...
F1 flashing signal &...
Excessive condensation
Door open adjustment
oven showing f4 even after...
