Question about Sharp R-1490 Microwave Oven
Powerless microwave My microwave quit working. I changed the power fuse, which brought power back to the unit, but as soon as I turn it on, it blows again. Any suggestions as to what is blowing the fuse
  • Anonymous Jun 29, 2008
    I have exactly the same problem. replaced the fuse behind the control panel, plugged it in to power, saw the panel light up (i.e. the clock was blinking as when the power goes out), pressed the start button and it blew the fuse again.
    the model is R-4H84.
  • Sharp Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
The HV capacitor or the HV diode may be in short, check these parts, discharge the capacitor before touching anything.
Maybe something is shorted to ground.
Posted on Feb 17, 2008
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Microwave door latch
Being a brand new unit it should work properly. If it did not blow a fuse then its ok but it will only get worse with time. Have it exchanged as soon as possible.
Oct 15, 2013 | Zanussi Microwave Ovens
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
As i turn on microwave it blows the fuse. what could be the reason.
try using it at a different location in the house(different circuit) if it also blows that fuse, there must be a short in the unit. do not use. if it works means line in the kitchen is overload, and you need a higher fuse rating or breaker.
Sep 10, 2009 | Microwave Ovens
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Blows the 20amp fuse when the heat is turned on
It has a short. Its likely the power $5 power diode.
It has to be checked first if its good then the mag tube may be bad.
Its likely the diode. You can test it by removing it and using a ohm meter to test it. Voltage should only flow 1 way if it flows both ways its shorted.
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power
You mentioned taking the "buttons" off. That may not give you complete access to the units motherboard or power supply area. Unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Jan 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1490 Microwave Oven Logo
127 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
