Question about LG Shine KE970 Cellular Phone
Bluetooth Problem I have been using blue tooth and it worked, more or less. Last week it just stopped. It connects and when I tap it the command list comes up on the phone but there is no audio and if someone calls me I can't hear them and they can't hear me. Had the blue tooth piece replaced and nothing has changed. I wonder if I have turned something off on the phone by mistake. everything else on the phone works OK.
  • Sprig Feb 16, 2008
    I am using the Jabra BT125/.
  • MR R
    MR R May 11, 2010
    what bt headset are you using
Insde the phone setup for the bluetooth there is a mute function some phone have a mute button located on the edge so they can talk privately to someone else while holding a conversation about a problem etc also the headset has a mute button check that this has not been set in some way
Posted on Feb 18, 2008
How do I get the blue tooth to cancel the "in use" signal"?" The phone or car functions do not respond to any prompts.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
Apr 24, 2014 | Apple iPhone4 4G iPhone 4
How to add remote control (connecting via Bluetooth/Infra-red) for a laptop to play Media player?
http://www.retrevo.com/s/SMK-Link-VP6600-Universal-Remotes-review-manual/id/2881bh146/t/1-2/
this is the blue-tooth solution ..it is a remote for the player via blue-tooth ..its charges on the card slot ..and last up to one week
Or if your cell phone supports ..some models can be used to remote control the laptop via bluetooth ..usually all you have to do is install the feature in the phone..
o r..this is a infrared one ..
using a usb connection ..
http://compare.ebay.com/like/140411021885?ltyp=AllFixedPriceItemTypes&var=sbar&afsrc=1
Jan 20, 2011 | Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I cant connect using blue tooth
Start your bluetooth on PC and then in your HTC......I hope u have bluetooth software in your laptop......if not install it....try to search devices in ur laptop dont forget to keep ur HTC in visible mode. when ur laptop identifies the devices try connecting it.....best way that ur laptop gives a key n type the key on ur htc it will connect.....n u can strt data transfers easily......hope this helps......
Mar 11, 2010 | HTC Computers & Internet
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
I have an audi S4 2007 what is my blue tooth pairing code???
When u want to pair your bluetooth phone the first time, you must do this in the first 30 seconds after ingnition. This is the only period your audi bluetooth carkit is in search mode. Follow these steps to make it work:
Put your bluetooth phone in search mode, then start your car. Your phone will now detect something like AUDI UHV-1 or similar. Connect to this device, and enter either code 1234 or else code 0000. Your phone will then connect. Command your phone to keep the Audi device listed as a save connection, which can automatically connect. The next time you enter your car it will connect by itself (after ignition that is).
Dec 21, 2008 | 2007 Audi S4 Convertible
Bluetooth Share folder
You can can change the default blue tooth folder to phone memory.
Open connection manager > Tap on settings > Select bluetooth >Tap FTP > disable Enable file sharing by removing the check mark next to it > Or you can change the defualt folder from bluetooth share to my documents on the phone menmory or storage card
Thanks
proton
Oct 14, 2008 | HTC P3300 Smartphone
Blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Jun 14, 2008 | Computers & Internet
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
LG Shine KE970 Cellular Phone Logo
79 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
