Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Doesn't seem to pick up little articles anymore
Worked fine for the first little bit, I've cleaned it out regularly, is the wind tunnel filter supposed to be spinning ? If so, it's not anymore! Could this be the problem?
  • aliasbella Feb 17, 2008
    Thanks for the quick response ..... works much better now!
    President:
  • 1,673 Answers
You have to turn the filter, there is a knob on the tank lid that you turn to help clean the filter. If the filter looks pretty clogged, then it needs to be replaced, or cleaned if it is one of the washable ones. You could have a clog in the hose, or down below where the brush roll is the inlet where the dirt first comes in. Is the brush turning? You may need to replace the belt and/or brushroll. Down in the noozle asm, there also is a vale that will open and close depending on the handle position, it may not be working so it seems like no suction when you do the floor.
Posted on Feb 16, 2008
  • Lauren Junge
    Lauren Junge Feb 17, 2008
    You are welcome.
Height Adjustment on Hoover Wind Tunnel doesn't seem to do the job.
You changed the belt that drives the brushroll, it is a flat stretch belt. The V belt also should be replaced every year or two max. It will not be stretched out like the flat belt but with normal use the side of the v will of wear off and the belt will be a little thinner which can cause it to slip on the pulley. The V belt drives the transmission. The flat belt goes from the transmission to drive the brushroll. The burning smell could come from the V belt if it's slipping real bad.
Mar 15, 2017 | Vacuums
Dosenot seem to clean the carpets as good as before, we have cleaned the filter and keep the canister cleaned. What else might it be; I bought it for the express purpose to clean animal hair off my...
I'm sorry to hear you're having difficulties with your DC17. This machine should have no problem dealing with animal hair, so if it doesn't seem to be picking up as well as usual, this may be due to a blockage. The easiest way to check for this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
Although I note you've already cleaned the filter, you may want to take a look at the video below to make sure you've washed it as recommended - in normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve the issue, but if you're still concerned about your machine, please call us free on 1-866-693-9766 - or if you email your details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
Feb 09, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Low suction
Hi Megan,
I'm sorry to hear you're having difficulties with your DC17. If it doesn't seem to be picking up as well as usual, you may have a blockage somewhere in the machine. To check for this, please follow the steps shown in our online support guide:
Although I note you've already cleaned the filter, please see the video below to check you've done it correctly. In normal use, the filter should be washed at least once every 3-6 months in cold water. Don't use detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve your issue, but if you need any further assistance, please call us free on 1-866-693-9766, or email askdysonUS@dyson.com so we can help.
Kind regards,
Jack
Dec 18, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson has, against all it's proclamations, lost suction. I clean the filter regularly (wash it out, etc) - I replaced the hose (it had a hold in it). Any thoughts?
Sorry to hear you're having difficulties with your DC24. If it doesn't seem to be picking up as well as usual, and you've already washed the filters, it's likely that there's a blockage somewhere in the cleaner. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
You might also want to take a look at the video below to confirm you're washing the filters correctly. Under normal use, it's important to wash both filters at least once every month. Use cold water without any detergents, and ensure the filters are totally dry before replacing them - this may take up to 24 hours.
Hopefully, by clearing any obstructions and washing the filters, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
Kind regards,
Jack
Aug 23, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson is 8months old now its lost suction the brush turns thats it.
Sorry to hear you're having difficulties with your DC17. If the cleaner doesn't seem to be performing as well as usual, you may need to wash the filters, and check for any obstructions. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
Under normal use, the filters should be washed at least once every 3 months. The correct way to do this is shown in our video guide:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Hopefully this should resolve your issue. However, if you've tried these steps and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will get back to you as soon as possible.
Kind regards,
Jack
Dyson Customer Service
Aug 09, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 16, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover wind tunnel
A clog or partial clog is what causes the motor to overheat, then a thermo protector will cut off and the motor will stop until it cools down. So either you do have a clog, in the hose or down by the brush roll. If they are clear, and the filters are clean, then maybe the thermo protector is bad and needs to be replaced.
Mar 08, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
62 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
