Question about Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator
Fridge problem I have a 5 year old Hotpoint. Freezer on top. Freezer and ice maker working fine. Firdge is not getting cold and food is spoiling. What do I need to look for? I don't have a book on it, fridge came with the house when it was built and no paperwork was left for it. Thanks.
  • 2 more comments
  • ljmooney Feb 17, 2008
    This answer has nothing to do with my problem. The problem is the fridge, not the freezer. And I did check - there is no build up on anything anywhere inside the freezer or fridge. It soulds like the thermostat to the fridge - is there a separate thermostat to the fridge than the freezer? Can I buy one and replace it myself or do I need a tech? Where would I even look at to find the thermostat? Thanks.
  • MICHAELJFOX Sep 01, 2008
    My hotpoint refrigerator is not cold inside and thermostat does not seem to work. Freezer is fine. A kid used to keep the door open.
  • robert samples May 11, 2010
    do you hear a fan running in the freezer if the thermostat was the promblem the whole unit would be thawed do you hear a fan running when you open the freezer door
    well first off as master tech said the freezer does all the cooling for the whole unit there is nothing in the bottom that cools the hot air is drawn up from the bottom and through the evaporator in the freezer chilled then blown down through the discharge vent to the bottom three things on that model will stop this defrost problem,frozen drain in the freezer,or the freezer fan not running
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Posted on Jul 26, 2008
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool fridge with top freezer.( no ice maker )
check if you have frost build up at the back side of the freezer section.
if you do, then it is a defrosting problem.
you could have a problem with the defrost timer, the defrost heater , or the bi-metal.
if there is no frost accumulation, that would be something more and you have to elaborate on what you observe with the unit to help me further troubleshoot your unit.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a 10 year old side by side refrigerator. Model No. ED20TKXDN01., Ser. SG0437491. The freezer portion works fine, plenty of cold air. The refrigerator portion is not staying cold, food is spoiling....
take back panel off inside freezer and check if there is ice build up. if so, melt off with a hair dryer and see if it works then. get back to me if you want
Aug 21, 2008 | Whirlpool Refrigerators
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator Logo
210 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
