Question about Epson Stylus C60 InkJet Printer
Epson c60 will not print with windows 95 gateway computer
My epson c60 will not print with my windows 95 on my gateway computer. it used to print fine. i changed the color cartridge, but the ink light keeps blinking.
  • 97 Answers
Take the cartridge out clean the contacts with a cotton bud re-insert ana dtry a cleaning process via the HP software sometimes even with a new cartridge it will not print emediately
Posted on Feb 16, 2008
I'm trying to share my epson stylus c60 printer on a local network. The other computers, one running Vista home premium and one running 64-bit Win 7, can see it, but can't communicate with it or send a...
Goto controll panel and double click on printer and faxes, click on add printer on the computers you want to have access to the printer.
You should get "welcome to the add printer wizard" window up, click next, select the option you want to use, check the "a network printer" and click next. Check "browse for printer" and click next.
You should now have a window where you can choose the printer on the network you want to use, in your case the c60, once selected click next and set it up as the default, click next until out of add printer wizard. You should now have a printer that the computer can use. hope this helps and post back what happens. thanks.
Mar 25, 2010 | Epson Stylus C60 InkJet Printer
I can't seem to find a way to clean my Epson C60 ink nozzles. I'm running Mac OS 10.5.6 Thanks. -Bill Carter
Hi Bill
Go to the C60 online manual at:
http://support.epson-europe.com/onlineguides/en/sc60/index.htm
and select How To, Maintenance, Cleaning the Print Head.
This explains very well how to clean the print head etc using either the printer software or the printer control panel, for both Windows and the Mac.
Mar 15, 2009 | Apple Epson Stylus Color C60 InkJet...
Installed H/P 6300C scanner now epson C60 wont print any idea how to remedy ? lite for out paper or ink comes on text says communication error . Many thanks *****
The H/P 6300C can be plugged right into you router using a network cable. then you can plug your epson C60 back into your computer.
Jan 04, 2009 | Office Equipment & Supplies
Get an error message when trying to print test page
Please uninstall your printer then reboot the computer. Make sure your printer is switched off, then insert your printer installation disk and follow the instructions. Do not turn the printer on unntil asked to.
Please post a new comment if you need further assistance.
Dec 13, 2008 | Epson Stylus C60 InkJet Printer
EPSON C60 PRINT BLACK
If you are running windows go to Control Panel, Printers, Select Printer Preferences and turn on either print in Grayscale or Print in Black only.557e203.jpg
Nov 03, 2008 | Epson Stylus C60 InkJet Printer
Epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Oct 23, 2008 | Epson Stylus C60 InkJet Printer
How to connect my epson stylus c60 to my computer
What Operating System do you have? ie; Windows XP, Windows Vista?
  1. Do you have the instructions and Print Driver for the printer?
  2. Do you have the printer cable to connect to PC?
  3. If you have 1,and 2 then
  4. Put the Disk that came with the printer into the computer.
  5. It should start up if not you will need to go to my computer and look for the drive you put the disk into and click on it and then Select the Run.EXE file
  6. Follow on screen instructions
  7. Once prompted connect the printer cable to the printer
After all drivers are installed you should be able to print from your PC.
Hope this helps
Jul 05, 2008 | Epson Stylus C60 InkJet Printer
Epson c60 not compatable with windows vista
I have an Epson C60 and Vista has the neccessary drivers in box. When Vista is running just connect your C60 and it will do the rest.
I have so far had no problems. The only thing that I can see is missing is the option to preview via the printer software.
Mar 20, 2008 | Epson Stylus C60 InkJet Printer
Epson stylus c60
hmmm..is the cable from the printer to computer happy? unplug it, and see if it shows on the computer screen, when you plug it back in.
Mar 05, 2008 | Epson Stylus C60 InkJet Printer
Epson C60 inkjet Epson Printer Utility
Try downloading the latest version of the status monitor from the Epson web site. This should sort your dilema.
Apr 01, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
