Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Tubing to water dispenser is broken
I need to know how to access the tubing to replace it.
    President:
  • Kenmore Master
  • 2,651 Answers
Form where to where do you need to replace it?? you can get a roll of the tubing from a decent hardware store, and for the most part all lines run with in the machine are accessable from point to point, even within the freezer door itself should be run through a channel that you'll be able to pull a new line through
Posted on Mar 01, 2008
Water dispenser has ceased dispensing water.
Water tube is frozen inside the door. Bad design. I use boiling water, a small plastic flexible tube and appropriate plastic syringe to force very hot water into the tube pushing the small tube into the dispenser tube. At some point it will stop because of the Ice blockage, more hot water through the small tube will soon unblock the line. A retrofit "heater" was available at appliance parts stores. I installed one. It stopped working and I haven't bothered with another. The Ice supply line is separate from the water dispenser and Y's somewhere to get water into the hinge for the door access to the Water dispenser in the door. Hope this helps.
Jun 15, 2015 | Refrigerators
Hose from under frezeer door to water dispenser broken. CAn't find part number for this hose. How do you get the hose the new hose in. Does dispenser come out the front.
That could prove to be difficult. The doors are usually filled with polyurethane foam. And you may need to remove the inner liner to see if you can gain access to the tube. It is rar that the door dispenser will come out because of that foam. You can try. This hose is usually just a length of 5/16 plastic water hose available at a hardware store.
Apr 24, 2015 | Refrigerators
Water fill tube broken Plastic fill tube in door water dispenser broken. How does it come out to be replaced?
If the area that is broken is accessable all you need to do is pick up a quick connect coupler of the correct size for the damaged tube available at most hardware stores. To determine the tube outside diameter place a ruler across the surface of the tube and note the measurement. It is most likely 1/4" or 3/8" diameter.
Jan 14, 2011 | Whirlpool Refrigerators
Broken water dispensing tube
you h ave a project in front of you. you are going to have to remove the door entirely from the cabinet, including electrical and water line connections. you will then have to remove the inner door liner and gasket, to access behind the dispenser module. you will need to pull the line out from the bottom, carefully, and replace with new water line, then replace gasket and liner, and reattach door.
Good luck.
May 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a Hotpoint HSS25GFTA BB. The water is not dispensing. I know the microswitch is making and water is pumping because I disconnected the tube on the bottom of the frezzer door and it squirts water...
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
Mar 16, 2017 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water in the bleach dispenser
The bleach dispenser is a syphon system. When you put in the bleach , it fills the reservoir to a point just below the syphon point. Your bleach tray has a tube attached to it, with a loose cap around the tube that causes the bleach to be delivered to the washload when the water is added. Remove the cap over the tube in your bleach tray. You'll also note a similar arrangement for your softener dispenser. Clean both caps and tubes. Make sure that the caps fit properly back down over the tubes. The syphoning effect will work only up to the point that the circuit is broken by air. If your cap sits up too high, the syphon effect is broken early, leaving residue (water) in the dispenser.
Best regards, --W/D--
Aug 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water dispenser spout broken
we had the same problem. My husband cut a flexible straw to the length he wanted, and crammed in in the hole. works great !! saved between $ 35.00 and $55.00 (labor was free)
Aug 06, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana SZD27MPW refrigerator water reservoir replacement
The watedr reservoir ha a crack. what do I need to do to repair. Do I need to replace it? Please let me know. GE Refregerator Models 20-27
Mar 25, 2009 | Refrigerators
No water!!!
Your water valve has two seliniod valves. One for the ice maker and one for the drink dispenser. When you push the water dispenser lever, you should hear a small click. It is a micro switch inside the dispensing housing. The plastic frame may be broken that holds the switch. Your water tubing or water tank in the refrigerator may be frozen. A frozen water tank or tubing will not allow you to dispense water. If your water tank is frozen, you may need to replace your air diffuser(damper) if it happens again. It may be leakin cold air. I have these parts on Ebay as username, themackshack. Good luck!, Mack
Jan 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
