Question about HP OfficeJet 6110 All-In-One InkJet Printer
6110 won't print w/imac
Ever since I got my imac, my 6110 has lost it's mind. worked fine w/old gateway, but now spits out paper like there are plenty of trees, then won't print half the time, or prints only part of item. sometimes works if cut/pasted to word, but mostly just wastes paper.
  • 181 Answers
You need to have the right driver installed on your mac. I assume your new mac came with the leopard OS 10.5? If so than the CD wouldn't have installed onto the mac.
HP so far has not released any drivers for your printer for the 10.5 but you can still print if you assign the drivers yourself. Click on the apple in the top left corner and go down to system preferences. Then click on print and fax. You will see 1 or more 6100's in the list. Click to highlight one and then at the bottom left click on the minus sign. If it asks if your sure you want to delete click on delete or yes and repeat until all 6100's are gone. Then click the + sign and make sure you are on the button on the far left I think it's default brower. You should see your printer listed. Click on it to highlight and then down at the bottom click on the drop down next to where it says print using - and choose select a driver to use. Type in 6100 and your printer should come up. Add it and try to print.
If that is a no go then do the same steps but instead of using 6100 series use the P1000 driver for the photosmart printer - gimp works better than guten if given the choice.
Posted on Feb 28, 2008
Having problems printing with imac desktop. It will print with windows laptop.
I can not print from my imac to my kodak 5210 which worked fine with our old laptop
Jan 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
HP 6110 all-in-one.....Connected to PC correctly...it has ink.....it prints a report...BUT it will not make a copy when an item is placed on glass and it will not print when right clicked....What does do...
Try printing it from the ADF (Automatic document feeder) if it prints from there... If same thing happens just check if the scanner bulb lids up or not... If not then its the issue with the scanner bulb
Oct 21, 2010 | HP Photosmart C6100 All-In-One Printer
Printer won't print.
sounds to me like perhaps the printer drivers are really unhappy. you'll need new ones from www.kodak.com
http://tinyurl.com/6qcpgy
Jul 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Hp officejet 6110
Ok, By any chance, do you have a Windows Base Platform to try this Printer? RandyXi wizztech@gmail.com
Dec 27, 2006 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
