Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi hd 1080
I have a mitsubishi hd1080 - 1999 - ws65903. The screen will not strectch to fit. the screen is grey on both sides. How do I get it to stretch? I do not have an owners manual as the tv was given to me. I do have an hd, dvr box from cox.
  • 979 Answers
The format of what you are watching plays a major part in whether all of the screen is used. If the program is 4:3 the screen will remain pretty much square. 16: 9 would be the most desirable for filling all the area. Go ahead and acquire a manual, they're not much...accordianman
Posted on Feb 27, 2008
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
I have HD 1080 and the images are sterched at the
You should be able to change the aspect ratios so your images arent distorted.
Jun 15, 2009 | Televison & Video
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
377 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
