Question about Vacuums
Rainbow se d4c
Need to know how to take the lower housing and inner baffle plate off the motor. Can't take the gasket flange off the baffle plate due to extreme rust
    President:
  • 1,673 Answers
There a number of screws that you have to get out. Maybe a screw extractor may work, last resort would be to drill the heads off of the screws, then after the plate is off, remove what is left of the screws.
Posted on Feb 16, 2008
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
The rainbow sat for too long on the water now wont run
So depending on how long, you may have rusted out the bearings in your motor, especially if it sat so long as to eat the glue off of your gasket.
Sounds like you may need a new motor, gasket, baffle plate and separator.
Rainbow series vacuum main unit parts
GoodVac.com
800-775-6586
Apr 14, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I just purchased a rainbow D4C, after purchasing i was told i should have purchased the SE model. whats the difference?
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 02, 2010 | Rainbow 75th Anniversary Canister Vacuum
What's the difference between the rainbow D4C SE and the D4C?
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
How do you disassemble Rainbow D4c to replace power cord? Took four screws loose but unable to see how to get housing loose...
Gently pull on the rubber gasket that seals the water tank to the canister. Although there are more screws under there - they aren't necessary to remove only to replace your cord. It is the gasket that is holding the motor flange and the plastic housing together that hinders your progress. If you're gentle about pulling off the gasket and it's in good enough shape, you can usually put it back on with some rubber cement (the same thing it is originally attached with) when you're finished. If the gasket breaks, it would have to be replaced - but not a big deal - they aren't really very expensive.
May 09, 2009 | Rainbow 75th Anniversary Canister Vacuum
Can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
May 05, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow d4c
Take off water tank, remove the screws to separate the top from the bottom, take out the screws inside the top and take out the plastic shell and the switch will be there.
Jan 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
165 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
