Question about Tomtom One Europe v2 GPS Receiver
CANNOT RECHARGE TOMTOM
WILL NOT RECHARGE.TESTED LEAD WHICH IS FINE SO WONDERED IF IS EASY ENOUGH TO BUY AND REPLACE CONNECTOR ON UNIT?
    Novelist:
  • 158 Answers
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Posted on Feb 24, 2008
Hello, i have problem with TA-709 headphones batteries, i need to know if is there any possible replacement,
You are correct about 1.5 volt not being shown as rechargeable. However that 1.2 should be enough. You need to be able to test those batteries or buy brand new alkaline ones.
Feb 25, 2017 | Audio Players & Recorders
I just received a Rankin Delux Commercial Heater from a friend. He stated that everything works well except the igniter. I suspect it will need to be replaced and I am seeking advice on how easy or...
Piezo ignitors are very easy to replace, most have a male/female connection to the lead. Just pull the lead and unscrew the nut behind the plate and it should come off. A few will have a spade connector and these are also very easy to replace.Replacement ignitors are very cheap just make sure it is like for like swap. There a push piezo ignitors and electronic ignitors on the market.
May 27, 2011 | Rankin-Delux Bronzetone Patio Heater
My sansa just stopped working one day & would not charge. As nothing had happened to the unit to damage it I just assumed the battery was gone. I ordered a replacement battery and installed it - it...
Buy it a new cable. Get one marked as USB 2.0
I have a ebook reader that was not charging via USB, the cable not fitting snugly.
I works fine with another cable, and, yes, it is a nice, snug fit.
The socket on the unit might be damaged or there may be a fault on the circuit board, but a loose connector is more likely.
Feb 12, 2011 | SanDisk Sansa e250 MP3 Player
How do you replace the battery?
once you've removed the four Torx screws, get your thumbnail between the silver top and the dark grey back and prise the top open by about 1/4". Then lift and ease the front out.
There are two leads holding the two pieces together (one for the battery and the other for the speaker) but these are long enough not to break and once the unit is open they are on connectors anyway.
hope this helps.
Jul 25, 2010 | Tomtom ONE 3rd Edition GPS
My Tomtom has been disconnected from the computer
Reconnect it to your comuter or buy a wall charger for it.Otherwise buy an incar charger-they are the most useful.
Jun 12, 2009 | Tomtom GO GPS Receiver
Tomtom speaker stoped working
More than likely the small spaker inside has siezed up!
You can puchase a replacement (search ebay for replacement speaker tomtom) for about 10GBP.
They are easy to replace - 4 screws on back of 710, pop out main unit, and remove 4 screws holding speaker, unplug and install new one - reverse to assembly once more.
I had a strange experience in Vegas when I took my tomtom710 on vacation. the tomtom was silent in the UK - speaker dead as a doedoe, however 3-4 hours in the Vegas heat on the dash made the speaker pop back into life!
Result I thought, however on return to the UK the temp had returned to below miserable and the tomtom didn't wanna play ball anymore.
So, tested the output internally with another temp speaker, all works fine - so just ordered a replacement "original" tom tom speaker to fully fix.
Jun 02, 2009 | Tomtom GO 720 GPS Receiver
Connecting GPS device to bike's electrical system
I misunderstood, I thought your battery was discharging DURING the ride. Put your meter in current mode. connect one lead to the battery and one lead to your TomTom wiring while the unit is in the cradle. How much current is is drawing? Now remove the TomTom from the cradle. Is it still drawing the same amount? If not, the TomTom is drawing power even while off and that is draining your battery.
Apr 20, 2009 | 2006 Yamaha Stratoliner
Usb port in Tomtom 130 not working properly
It sounds like your mini usb connector is damaged or one of the components near to it. If you're handy you can buy a replacement and solder it in. You will need a very fine tip soldering iron and a magnifying glass. The repair can be quite challenging as the components are surface mounted. If it's a damaged component near the USB connector that is damaged then this wont solve the problem.
I can fix it for you for a small fee if you dont want to attempt repair.
I've repaired about 20 tomtom units with similar problems. I charge around £35 for this including return postage
Mar 27, 2009 | Tomtom ONE 130 GPS Receiver
Tomtom will not start
I had a similar problem, ther is a minute reset button where the connector is under the unit, it requires a pin to press it!
Mar 22, 2009 | Tomtom GO 510 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
288 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
