Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
How to back up Hard Drive. I have 160 GB/Go, USB 2.0
I have ran Quick Test Successfully, Extended Test Successfully. Now what? I am afraid to go further without help. Thanks
  • 121 Answers
Connect it go to my computer right click on the drive select properties / tools/ then u should c backup
Posted on Mar 03, 2008
My seagate device driver is not installing plz help me
1. Download and install "USB Disk Ejector beta 4"
2. Switch PC off.
3 . Connect seagate
4. Power PC on and press F8 while windows booting up
5. Enter just "Safe Mode"
6. when powered up, run "USB disk ejector" and your drive should be displayed. Eject the disk, once it disappears of the list unplug the USB cable and wait for the LED to go off the drive. Then replug the drive back in and wait until "USB disk ejector"recognises the drive and repeat this step a few times 3/4 times then eject and reboot PC in Normal mode.
May 11, 2012 | Seagate 320GB Portable External Drive ...
Computer hangs regularly, usually after just over an hour. But occasionally after a few minutes. Attempts to check 1TB disc unsuccessful (Extended WinDlg122) because computer freezes half way through...
Sounds like 1tb hard drive is passing quick test and then freezing extended test. And if it doesnt freeze during the 200gb test then I would guess the 1tb is going bad. Check the event viewer in windows under system and see if there are any Disk errors with a red X and that ideall will say disk drive 1 or 2 cant read it and yeah that would help confirm it is failing.
Mar 03, 2011 | Intel Core 2 Quad Q9400, 2.66 GHz...
1)How to find and remove the hard drive on the IBM ThinkPad T22 2647. 2)The comp appears to start but screen is blank
hi
to remove the hard disk, remove screws from small hard disk drive door (loacted on back of notebook), disconnect the hard disk by removing two screws (if applicable) pull tab to remove disk.
OR -----
if you do eventually get access to your operating system , when computer runs normally ---
run this test ,, read carefully and follow instructions - go to this link and download the program first
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70578
then follow instructions below.
Windows XP
  1. Click Start, select Search, then click All files and folders.
  2. Type hddquicktest_setup_60549818x86.exe in the search field, then click Search. This will locate the file you just downloaded.
  3. Double-click the hddquicktest_setup_60549818x86.exe icon.
  4. PC-Doctor for Windows will be installed on your system.
How to Run Lenovo Hard Drive Quick Test
Summary
Lenovo Hard Drive Quick Test is a diagnostic tool that tests the hard drives in Lenovo ThinkPad, ThinkCentre, and Lenovo 3000 computers running Windows XP or Vista released after January 2004. If you are experiencing issues with your Lenovo product, you may run this test to determine if your issues are hard drive related.
Running Lenovo Hard Drive Quick Test
To run Lenovo Hard Drive Quick Test from Windows, follow these steps:
1. Download the test to your computer.
2. Run the application install and choose the defaults. Once installed, the application will be placed under a "Lenovo Services" choice on your Start Menu.
3. If the application detects that the Lenovo System Toolbox is already installed, it will ask whether you want to continue the installation. This is because the new hard drive test is installed by default as part of the Lenovo System Toolbox.
4. Choose a drive if you have more than one drive.
5. Start the Test
Testing in process:
1. The test may take 4 to 6 minutes depending on the size and speed of the drive.
2. When the diagnostics are complete, a message will be displayed indicating that test "Passed", "Failed", or "further testing is required to verify the drive's proper operation". If further testing is required, start running the extended test. The test may take more than an hour depending on the size and speed of the drive.
3. When the diagnostics are complete the extended test, a message will be displayed indicating that the test Passed" or Failed".
4. If the test failed, contact Lenovo Support Center
Note: Lenovo Hard Drive Quick Test is included in http://www.lenovo.com/systemtoolbox
Lenovo System Toolbox is a full application of computer diagnostics utilities.
hope this helps
Nov 15, 2010 | IBM ThinkPad T22 2647 Notebook
The hard drive is flashing red and blue. Is it done?
Even though it is possible that your USB hard driveis corrupt, but
before you finally conclude, try out these few troubleshooting
steps.
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
goes
Hope this helps you out.
Thank you for using Fixya
Goodluck
Oct 07, 2010 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
I ran my PC doctor for a short test on my hard drive and the results cam back failed test with the code HDD535-s1- prediction threshold exceeded, engine 1 what does this mean and can I fix it myself or do...
I am afraid but this is the case of a damaged hard disk.Back up all data as soon as possible and call tech support as soon as possible if it is in warranty period.
Answer to your last question is yes , you had to purchase a new one.
For assurance of the correctness of this answer , check this thread .
Please Rate.
Thanks
Oct 01, 2010 | Samsung (SP1203N) 120 GB Hard Drive
Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Transcend StoreJet with 160 GB drive do not whant to stable work
hey dude..... it may b due  to lot of data on it ..or virus infection
format it onceusing command prompt on XP...
goto run ...type cmd...
then check whether if it is connected ...type format g:
{ if u storage on g }
Jan 03, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
USB External hard drive 160 GB not recognized by desktop Windows XP OS
Very possible your problem is that this drive is not externally powered and your desktop does not put out enough power to drive it.  I'm guessing your desktop is older.  Especially if your desktop is USB 1.0 this problem would occur.  Your best bet in this case is to either mount a newer USB expansion card into your desktop, or get another externally powered harddrive and transfer data over to it from this one with your laptop.
Nov 01, 2008 | Verbatim SmartDisk Firelite Portable USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
35 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
