Question about Kenwood KDC-MP2035 CD Player
How do you reset this deck
My deck rescently went into protect mode wich means theres a short in the speakerwire and I fixed that now I need to reset it but I cant find the reset button. Anybody know where it is
  • 1 more comment
  • jfrison Apr 22, 2008
    My player went into protect a few weeks ago, I took it back to place where I got and they said there was a short in the speaker wire they fixed it, but the player has went back into protect mode, my warranty is up what should I do?
  • harleyboss1 Sep 02, 2008
    hello i have a kdcmp438u is wont play its says protect thats all was pling ok then i washed bike whats next its only month old how do i reset
  • cavins_makan Jan 02, 2009
    My problem is that it displays PROTECT and not sure how to fix this....
    Problem Solver:
  • 3 Answers
There is a reset button on the left front of the deck>
Posted on Feb 08, 2009
It was very helpful even though i have different model i found reset button under the usb door it works thanks guys your great model was kdcmp438u
Posted on Sep 02, 2008
The reset button for the Kenwood KDC-248U is found by removing the removable face of the stereo. when that is done you should see it there
Posted on Jul 23, 2013
  • Help Jul 23, 2013
    the reset button for the Kenwood KDC-248U is found by removing the removable face of the stereo. when that is done you should see it there
Yea its just under the volume button, very tiny, and blck, it doesnt say reset its just like a pin ***** size.
Posted on Mar 20, 2008
Turning on problems
This usually indicates a protection mode...in which the system is shutting itself off to prevent damage. Check all your wiring including speakerwire and make sure no exposed wires are touching, connected in reverse polarity, etc.
Mar 12, 2014 | Samsung HT-C6730W Theater System
How to fix protection mode
First, check all of your speakers and speaker wires for shorts and/or grounds. If they all check out, try resetting your deck. If that doesn't work, you probably have a bad output ic inside of the deck.
Mar 13, 2012 | JVC Car Audio & Video
KD-R416 jvc deck. my deck is showing protect on the screen heellllpppp hahaha
protect mode means that you have a short either in the power supply or in the speaker leads themselves somewhere down the line.
Dec 11, 2010 | Car Audio & Video
My KDC W-3044 is shown Protect. what should i do???
If it is in protect mode then you have a short in your system. A blown speaker will cause it to go into protect mode, also if there are any power supply problems like a loose ground wire or a sketchy connection at the wiring harness it will also trip. My advice is pull the deck check power supply and ground and wiring harness, if it doesnt go away you know its the speakers.It may however need to reset and you will need to unplug the wire bundle from the deck for a moment before getting into the messing with the speakers or wires. Hopefully that cures it so test it and see. Okay if that didnt fix it then you likely have a blown speaker somewhere in the vehicle so get that replaced and rock on.
Dec 11, 2010 | Kenwood KDC-W3534A CD Player
Kenwood kdc-mp442u protect mode came
First of all , your Kenwood shows only Protect on the display when your speakerwires are conflicting with each other , but when you cannot find the problem there....
disconnect them one by one to see wich speaker in your car is conflicting (shortcuts).
Replace that speaker and your kenwood will work just fine.
I had the same problem here with a brand new Clarion speaker .
Oct 08, 2010 | Kenwood KDC-MP442U
KENWOOD DECK FLASHING (PROTECT)
protect mode means some speaker wires somewhere in the car are grounded out or are crossed... find the short and it will fix the problem. try testing all of the speakers one by one from the wiring harness... you'll find the problem. Good luck.
Nov 30, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
This deck is in protect mode
This is what the owners manual says about Protect mode......
The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protegtion function is activated. Wire or insulate the speaker cable properly and press the reset button.
Mar 13, 2009 | Kenwood KDC-X590 CD Player
Protect mode Kenwood KDC MP438U in dash reciever
Anytime there is a short circuit or your battery down low enough you will recieve this signal. If you press the little "reset button" using a small pin or screwdriver your unit should reboot without the "PROTECT" signal. If seeing this "PROTECT" sign is a result of jumping your car, this will fix it. If the signal persists, then there is still a short circuit and you need to check your connection with the battery. Most likely it is touching the chasis or some othere metal.
Jun 27, 2008 | Car Audio & Video
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
My stereo is flashing the work "PROTECT" across the front
In a Kenwood deck, "PROTECT" usually means that one of the speaker output wires is shorted. The first thing to do is pull the deck and inspect the wiring at the back, making sure there aren't any pinched or exposed wires. If a speaker wire is pinched against the deck chassis, or bare wire is touching dash metal, it can cause your problem. If you don't see anything obvious, disconnect all speaker wires from the deck, then turn it on. If it still flashes "protect", then you have a defect in the unit. If not, then re-connect the speakers one at a time until you find the one that causes it to go into Protect mode. Usually if you don't find a pinched or shorted wire behind the radio, the problem can be found at the speaker itself. This is especially common if you've installed after-market speakers; if a speaker terminal connection has come loose and is now touching the speaker basket or mounting surface, it will shut down the deck.
Jun 07, 2007 | Kenwood KDC-MP5032 CD Player
Kenwood KDC-MP2035 CD Player Logo
2,091 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
