Question about Kitchen Ranges
Err codeF2EO Stuck Key onContol panel touch pad
The control panel started going haywire in the middle of baking in the oven.Know matter what you would put the setting for the oven on they would always return to the setting of Convection 325F bake.It would always enter anyother setting on the display but go back to convection 325 when releaseing thetouch pad from the other setting.I shut the power to the range off and things seemed normal for a few minutes and the oven seemed to work properly.But then went to bake325f convection again,then to err F2EOStuck Key on control touch pad panel.Now it stays on the err F2EO setting and the oven doesn't work.The day before my wifr cleaned the top of the stove and contol panel with Comet.I was thinking the membrain switch might be shorted out.If so i need to know how to get the front control panel off to change the membrain switch.
  • 2 more comments
  • bassboss23 Feb 16, 2008
    How do i change the touch pad in the control panel?I've looked at the parts breakdown sheets and been to the KitchenAid website with no results.Nobody wants or can't seem to give me any verbel instruction.
  • bassboss23 Feb 17, 2008
    Model No.KERA807PSS01 KitchenAid Smoothtop range
    domare50@yahoo.com and thank you!!!!
    Thank you for sending the breakdown manual.It showed me exactly what to do to replace the touch pad in the control panel.All of you deserve two thumbs up for coming to my rescue.I would recommend your site to everyone.Thanks Again For A Great Job.
    Everly Grateful
    Doug Reynolds
  • 770 Answers
Ok first off i need your model Number so I can look up the proper code and also get you access to the switch (touchpad) so plz post your model and we will go from there
Posted on Feb 16, 2008
  • 3 more comments
  • Gary Davd
    Gary Davd Feb 16, 2008
    get me the model Number and i can walk you thru this
  • Gary Davd
    Gary Davd Feb 17, 2008
    I have the breakdown manual and the step by step info you need to replace it please post your email and i will send it to you in PDF format
  • Gary Davd
    Check your email
  • Gary Davd
    plz rate this Call
  • Gary Davd
    Plz Rate my service THANKS
  • 19,396 Answers
Here is a list of error codes and solutions. Hope it may help. http://www.repairclinic.com/0078.asp
cheers
    Genius:
  • 1,665 Answers
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
I try to turn on and when I do the temp starts going backwards until it is off. The clock will do the same things after I try resetting the breaker.
is there a time bake or something similar on it,sounds like it's stuck on that cycle,next time send the model number,could have a bad touch pad or clock assy. stuck on a time cycle so no matter what you do it's counting down
Nov 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
Controls won't work. Oven displays F7 error. Reseting oven or cycling power does not fix problem
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
  • NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Aug 23, 2010 | GE Profile JKP18 Electric Single Oven
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
What does code F1 mean?
Jan 04, 2010 | Kenmore 41389 Electric Double Oven
FO shows on led board for both ovens
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 06, 2009 | GE Profile JT952 Electric Double Oven
F7 and then clock is lit up. The key pad for upper oven is locked. I can'tget it to do anything. Before this it came up bake at 350 degrees and push to start. I did this, even I didnt want oven on. I also...
OK, this code is signaling an issue concerning the key pad or control board.
Determine if problem is with the Key Panel or Control by:
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
Jun 14, 2009 | GE JKP27 Electric Double Oven
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Mar 20, 2008 | Kitchen Ranges
Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
601 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
