Video/dvd/cd play but no sound from speakers
Have read manuel, tried all trouble shooting suggested, get sound from speaker "test" . . . HEEELLLLPPPP!!!
Yamaha Cinema Station DVX-S120
  • ginger76 Feb 19, 2008
    Tried this. My tele doesn't have a "variable" in stead of "fixed" option. I did, however try another test. This unit will also play audio cd's and that doesn't work either. I'm figuring it is a problem with the unit instead of just a cable or buttom problem. Any other suggestions?
Try changing "audio" setup in your TV to "variable" instead of "fixed", if you have that option on your TV set up... I have a Sony HD widescreen, and that worked for me...
Posted on Feb 16, 2008
My vizio m550nv has picture but no sound, tried all trouble shooting tips nothing worked
1. Check the audio setup menu, make sure that the internal speaker is turned on;
2. If the internal speaker is turned on, the problem is the main board.
3. If you use a set-top box (such asa cable box or a satellite box) it may be defective. To vitrifying it , please connect a DVD player to the TV, play a move, let see it has sound or not.
Aug 01, 2017 | Vizio Televison & Video
Not outputting to all speakers from CD, but does from DVD
Hi,.
With the indulgence of the others...
If I understand your problem right:
1. CD works only in Speaker A (but not in Speaker B);
2. DVD works on either or both A/B;
3. CD will work if plug into to VCR input but selector must be of another source (not VCR).
A couple of suggestions:
a. pls try doing again the reset as ginko has suggested but make it a bit longer, i.e. unplug it from the mains for a couple of hours;
b. since you have remove most of the wiring, why dont you try switch A & B. make the family room speakers the B while the speaker selector the A;
c. hook the CD (only) using the RCA cables (red/white) nothing else;
d. play any CD music and go through the paces of selecting source, speakers, surround/hall/theater/etc as troylove11 has suggested.
This would be now a simple setup, 1 source (CD) to 1 output/speaker (the family room) via the Denon. Try different settings. If the CD plays normally then, without changing any setting nor powering it off (but with volume level all the way down), remove the family room speaker wiring and replace it with the wires to/from the speaker selector.
the idea is to determine which is the real issue, the Sony, the Denon settings/hardware or the speaker selector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 15, 2008 | Denon AVR-3801 Receiver
Acer aspire s36646 sound yes sound when playing videos online no, help please just happened
That is weird. If you have a speaker icon in the right lower corner of your screen, right click it. A window should pop up, click on " Open volume mixer"and make sure the slider for your web browser ( And / or any other options) is at the top of the scale, if not drag it up by left clicking on it with your mouse and dragging.
Hope this helps, if not try Google. Good Luck
Nov 28, 2014 | Acer Computers & Internet
Onkyo ASV620 had been sounding great - now there is hissing along with sound on every channel
This is a tricky problem to trouble shoot, you will need a professional with additional test equipment to handle this, but since it is coming from both channels it suggest the source of the problem is in the power supply.
Apr 17, 2012 | Onkyo Audio Players & Recorders
Playing cd's no sound from the speakers when I have the cd/dvd option selected. When I put the reciever on I can hear dead air coming thru the speakers but not when I have the cd switch selected....
You need to find the manual and/or read and understand every indicator and evaluate how it affects the sound. Use a medium volume setting while troubleshooting.Check connections.
Start with the basics. Speaker test ok? FM ok. Digital sources assigned yada yada.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-8060-Receivers-manual/id/480ci254/t/2/
Jun 30, 2011 | Kenwood VR-8060 6.1 Channels Receiver
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Can not use the 5.1 surround sound system
stupid question, but you do have an optical lead connected? the hdmi will only produce stereo sound, you must also have an optical lead (aka tos link cable) connected to produce 5.1
Aug 12, 2008 | LG (GDR8164B) Internal DVD Drive
NOT RECIEVING SOUND FROM ALL SPEAKERS WHEN PLAYING CD/DVDS
CANNONT RECIEVE SOUND FROM THE FRONT N REAR SPEAKERS WHEN PLAYING A CD/DVD. THE RADIO AUTOMATICALLY PLAYS THROUGHTOUT THE CAR. WHEN SRC DVD/CD IS SELECTED NO SOUND EMERGES. SO I PUT ON THE DUAL ZONE. AND THE ONLY WAY TO HAVE SOUND IS TO HAVE ONE ZONE TUNER, AND THE OTHER DVD. WHEN I REVERSE THEM OF COURSE THE SOUND WILL SHIFT EITHER FRONT OR BACK. IF U CAN HELP ME FIX THIS AND RECIEVE SOUND FROM ALL SPEAKERS WHILE CD/DVD anPLAYING I WILL APPRECIATE IT. THIS IS COUPLE MONTHS NEW. IT WORKED ONCE OR TWICE IDK HOW THOUGH. AND NOW I'VE TRIED IT ALL BUT STILL CANT FIGURE IT OUT. i went into the zone control and turn off the rear and i still have nothing. pleease help
Oct 08, 2007 | Kenwood KVT-617DVD Car DVD Player
125 people viewed this question
 Grubhead
Grubhead
