Question about Fuji Pictrography 3500 Printer
Problems with Fujifilm Ask-1500 dye sublimation printer
I was using my printer today, and were printing lots of 6 x 9 photo's with no problems. When my film ran out i just replaced the film, but did not immediately changed the paper. I printed 8-10 more photo;s, before i had to change the paper. When i changed the paper the printer printed 1 more photo which did not come out very good. When i reprinted the photo it gave me a message saying " w55: paper end". The roll of paper however was brand new.
Now it wont do anything except display the same message. I did try to re-install the software and took out and then replaced the film and paper, and still the same message.
Any ideas would be very welcome.
  • Anonymous Aug 29, 2008
    need driver for 3500
SOURCE: fujifilm ask-4000
I have the driver disk if you need it.
Posted on Nov 02, 2008
magicard
  • 71 Answers
SOURCE: INk
Hi There,
It's difficult to diagnose 'Out of dye film' errors on the Rio 1 printers.
Does your serial number end with NP?
Can you hear the dye film motor running when the lid is closed?
Is the film actually moving? Try marking the rear (full) spool with a pen then closing the lid.
After the error, open the lid to see if it has moved.
While the lid is open, can you see a bright Red LED shining from just below the printhead?
Check that none of the dye film clips are broken.
Open the lid and remove the dye film spools.
Try to turn the small White cog just above the front-left dye film clip.
You should not be able to turn this (due to the gearbox on the motor).
If it turns then you will need to tighten the small grub screw which attaches the gog to the motor shaft.
I hope some of the above suggestions will be of help.
Regards,
MC.
Posted on Nov 12, 2008
  • 551 Answers
SOURCE: fuji xerox docuprint c3055dx printe
please check the pick up roller on the unit. maybe it is worn out. if so, please replace it.
Posted on Mar 05, 2010
  • 4 Answers
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Posted on Mar 23, 2010
Rider On Way
  • 1679 Answers
SOURCE: I havea FUJIFILM ASK 4000. The red light is
Try these step and it should fix the issue :
Cleaning or the printhead
The printhead is a 300 dpi thermal. If you raise the head and can see the glass face, there are 2 rows of heating elements that are used in printing.
As in all thermal heads, do not use any sharp objects to scrape on the head. I usually use a non volitile citrus cleaner or iso alchohol.
The plate beneath the head should also be checked for wear and cleaned to provide positve drive for the stock.
Regards,
Ron.
Posted on Nov 09, 2010
I have a Hiti P510s printer it has been in the storage container for a few months. It was working fine when I last used it but now it won't print anything.
when in storage unless temperature controled the heat gets too hot for the toner/ink, will ruin the toner/ink and the film cartridge
Dec 11, 2015 | HiTi Digital Inc. P510S Roll-Type 6" x 9"...
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
I want to use photo paper to print photos and the printer tells me I do not have the correct paper
When you give a print command (ctrl + P) You have the possibility to select the Print Properties. If you press that button, there has to be somewhere a possibility to select the right kind of paper. I don't know which kind of printer you have. This works well with inkjet printers. The settings in your driver has to match the paper you use.
If you have a dye sublimation printer (there is no ink, but a ribbon with coloured dye) you need the right brand of paper, because otherwise your printer doesn't detect the paper.
Jul 03, 2011 | Office Equipment & Supplies
My system is setup for dye sublimation printing. it has been perfect for 2 years, but yesterday, I noticed banding in the dark, heavy ink areas. I first checked the nozzles (clean) but I noticed the...
Hi, I recommend getting a set of Epson ink, run through a few head cleans and repeat the head alignment a few times if required.
Sublimation ink is a lot thicker than normal ink, this means a typical dye based printer may struggle over time. Genuine ink contains anti coagulants which prevent the ink from drying and a cleaning solution within the ink. If this doesn't work you can try removing and soaking the print head in distilled water but I would only recommend this as a last resort and only if your confident in doing this.
Jan 28, 2010 | Epson Stylus 1400 InkJet Photo Printer
What do I have to do if I want to use sublimation ink on Epson stylus photo 1290?Thanks
what you want is not possible. the Epson Stylus Photo 1290 does not use sublimation ink. it is strongly advised to only use genuine Epson ink to keep the print quality of your print head as high as possible.
Jun 22, 2009 | Epson Stylus Photo 1290 InkJet Printer
No true colours in Epson Stylus Photo 1400
Given that you are using a dye-sublimation ink I have to ask if you're basing the colours you're getting on the results on your substrate or on the finished product (after you've done the heat transfer).
Beyond that you should probably ask the supplier if they have a colour profile for their inks. If not you can look for one of the services available. I can't make any recommendations but communication with this company has been quite positive
Sep 01, 2008 | Epson Stylus Photo 1400 Printer
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
Mar 15, 2008 | Hi-Touch Imaging Technologies HiTi 730PS...
Fuji Pictrography 3500 Printer Logo
1,134 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
