Question about Refrigerators
Kenmore fridge isnt working
I have a kenmore refrigerator mod no253.74802408.I t isnt working for couple of days.I tried to reset the temp and unplug it and put it back again,but nothings is happening.Both the freezer and the fresh food has kinda stopped working.I can hear teh fan in teh freezer but the popciclle haaws melted and the ice maker isnt working.The fresh food storage isnt working either.There is no sound from that side.The milk has not spoiled but the food isnt cold either.I have cleared the freezer thinking it might be overloaded,but nothing has helped.Anything I could do to fix it begore I get professional help??????
PLZ HELP
  • 770 Answers
Check in the rear of the unit u will need to pull it out and remove the panel see if the fan (Condenser) is running is the compresser running?? is the compresser hottt?? do you hear a hum and then a click noise?? is the condenser dirty?? remove the front kick plate to see this.. After you have cked these things let me know and we can go from there
Posted on Feb 16, 2008
Refrigerator temp erratic
you will have to replace your thermostat of the fridge
you can find it near the light inside the unit
Sep 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Our Kenmore Pro side by side is still stuck. The service tech came out and replaced the control panel located in the fridge and that didn't solve the problem. There only thing working is a small fan in...
Sorry to say but your Service tech seems to be totally incompetent since the compressor still isn't working along with several of the other components. If that was the problems it should have reset itself the 1st time once it was installed. Have them send out another more experienced tech.
May 01, 2017 | Kenmore 60721 Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Our fridge isn't staying cold. We have taken off
Sounds like you fan isnt working...its inside the wall..inside take everything out and look for the screws..on the back wall..inside...the fans in there,,unplug and replace..
Sep 20, 2009 | Refrigerators
Ref. is not as cold. No light on temp control
Sounds like a control board issue. When you unplug the unit your are resetting the control board. Then after a while one of the relays on the board is getting stuck again.
Sep 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
