Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Torpedo projector i want to hook my laptop to this but dont know how...my laptop does not have the same hook ups................is there a hook up that is the red white yellow ends and then the other end can go into the laptop........
  • 1 more comment
  • Anonymous May 05, 2008
    I bought this projector to use in my classroom. I need to know how to hook it up to my computer if my computer does not have the red, yellow, and white hook up place.
  • Anonymous Sep 07, 2008
    i have a torpedo entertainment projector and need to hook it up to a laptop help!!
  • Anonymous Dec 28, 2008
    i had the same problem and this site helped to locate the product I needed to fix it thanks so much
  • 4 Answers
You need a machine like this one: http://www.cdw.com/shop/products/default.aspx?EDC=327045  copy & paste that into your browser address bar.  You can probably find them elsewhere too, but this is one place to get these things.  They take a VGA signal for video and a USB for power and convert them into RCA & S-Video, which are compatable with the projector. :)  Hope that helps
Posted on May 11, 2008
Need to reduce size of projected image from Senario Torpedo Entertainment Projector. I do not have a user's manual. How can the size of the image be changed?
Many projectors have you twist the lens at the front of the unit (or have a separate adjustment near the front). This unit may not have the option, in which case you will need to adjust the image size by moving the projector closer to the screen.
Oct 27, 2013 | Senario Torpedo Entertainment Digital...
Senario AL-100 Torpedo Entertainment and Game Projector manual
I bought a Torpedo Digital entertainment Projector but there was no Operations MManual. Where can I get them?
Feb 02, 2012 | Office Equipment & Supplies
Need to get a torpedo projector to work with laptop
Unfortunately, there is no simple VGA-to-RCA adapter cable if you're connecting to a composite video input (usually colored yellow) or s-video input. VGA output is separate red, green and blue video and synchronizing signals, and they all need to be combined. You need a VGA-to-video converter to do this.
If the projector has component video input jacks, then you can buy a simple adapter cable.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Radio Shack Cinego D-1000 Multimedia...
How do I hookup my torpedo projector to a laptop?
Well for one, You leave out important information out of your question. Does your laptop have a composite out aka RCA yellow connector for video?. Need information before can give you an answer.
Oct 15, 2009 | Senario Torpedo Digital Game Projector
Hook-ups for computer
Yes, any computer with a RCA aka Composite yellow video connector has the option, then make sure all drivers and or software is enabled, on laptops usualy its a FN and F11 type key combo, Refer to your manual for the computer and or laptop for details if it has the right connector, and how to use that option. Remember the topedo uses RCA/Composite connectors. There is adaptors out there, but add int he cost of more hardware
Apr 27, 2009 | Senario Torpedo Digital Game Projector
Dell laptop connected to a projector. Cannot display on the laptop screen and projector at the same time.
i do the same thing sometimes. i dont think you can have the same on both screens so what i do is extend my desktop on to the projector in display properties. do you know how to do that? that might be the default when you hook up something for a second monitor. what are you trying to do?
Jan 21, 2009 | Dell Latitude D600 Notebook
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about: http://en.wikipedia.org/wiki/VGA_connector
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
PowerPoint and Projector (InFocus LP640) Incompatability
I am unsure of this from your post, but don't try to hook the projector up to the laptop while either one of them is on. Power both the laptop and the projector off, hook up the projector to the laptop, then power on the projector first then the laptop. If you are already doing this, I apologize for stating the obvious.
Jul 03, 2007 | InFocus LP640 Projector Multimedia...
Toshiba tdp-t9 (everyday t.v.) with no hdtv hookups
Yes you can hook up your Projector to ur cable box thru componet to RGB conversion Cable. that will work. i am also there on v_dhiman@hotmail.com
Apr 16, 2007 | Toshiba TDP-T9U Multimedia Projector
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
512 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
