Question about Toshiba Satellite A105 Notebook
Satellite i get a signal from my satellite but its always written no service availble so i cant get any channels
    Genius:
  • 3,587 Answers
Signal from satellite? as in your satellite dish for net access? or from the computer itself?
Posted on Feb 19, 2008
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Activated Sirius service, unit says "no channels available"
Turn the unit on for about 15 minutes. Cycle through the channels, starting from channel 1. You won't have to go through all of them, but this should get it working. If not, go to your account online, or call SIRIUS and have them refresh your signal.
Oct 30, 2010 | Sirius Satellite Radio Sirius Starbase...
No hd
Check the set's setup menu first to ensure it is looking at the cable input. Also, most providers (cable and satellite) sell HD service as an upgrade. If they are not supplying HD signal, your set cannot display it.
May 24, 2010 | Vizio GV42L 42 in. LCD Television
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Cant receive my channels i have had xm resend the activation signal 7 times and still wont work
First, turn the radio on and off using the POWER button on the radio - do not just turn off the car or unplug it. Next, make sure your 'sleep timer' isn't set. Next, check your antenna signal level and make sure you're in a location that has at least 2 bars - move until you do.
Now, make sure that you leave the radio ON Channel 1 for at least a half an hour. You should then have your channels back - when you do get all your channels back, turn the radio on and off with the POWER switch, not by unplugging the unit, or pulling it out of the dock or turning off the car. Okay?
Oct 27, 2009 | Delphi XpressRC XM Satellite Radio...
Signal 67% quality 0% auto scan set up no channels found
When you place a call, does it go from 4 bars of signal to 0. If this is what it happening, then your 9505 satellite phones signalling processor has become out of allignment, and needs serviced. We service all forms of satellite equipment. 877-258-3496
Oct 04, 2009 | Motorola Satellite 9505 Cellular Phone
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Toshiba Satellite A105 Notebook Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
