Dvd hookup i have a 24in dwt2405 i got a cyberhome dvd player i cant get to work ive plugged the audio and video to tv nothing happens. dont know what channel to turn t v to. thx
    Problem Solver:
  • 15 Answers
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Posted on Feb 16, 2008
I need a remote control and i need to know how to hook my cyberhome to a tv. Its a use one
you need to purchase cable wire (yellow/red & white) at least 3 feet..yellow is video red & white is audio...plug into the color jacks on tv...the remote is kind of hard this dvd model is discontinued....
May 19, 2010 | Cyberhome CH-DVD 300 DVD Player
Need instructions to set up Cyberhome DVD 1200 player
Useing RCA cables -(yellow video out) on the dvd go's to yellow video in on the tv. Then (red -right) out on dvd go's to red audio in on the tv . And white-left out on dvd go's to white-left audio in on the tv! and thats it
Dec 24, 2008 | Cyberhome Televison & Video
Left a dvd movie in player overnight - now have no audio.
Did you double check the connections from the DVD player to the TV? Maybe something happened to the connection overnight. If that dosen't seem to be the issue then the only other thing I can think of is that the Audio Encoding chip inside the player must have gone bad. The problem now is that it would cost more to repair the audio encoding chip then replace the whole player.
Sorry I couldn't help any further.
Thanks for reading!
May 01, 2008 | Cyberhome CH-DVD 300 DVD Player
How do i connect my dvd player to my dish cabel box
what conection do you want? Adio/Video? Conect to amplifier? Conection to tv... Look the word Video out from dvd and put it on Video input of your tv same proceedure of the audio.
Apr 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Dont have any image
Remove any disc which may be in the player. Make sure that the player is "on" (green light is "on" at front of player). Hold the "stop" button for at least 5 seconds (square symbol on the player is the "stop" button). This will reset the player to the most basic of video settings. The yellow "video" jack at the back is the basic output for video. The red and white jacks are the basic sound outputs (right and left if in stereo). Good luck.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Dont have any image
The DVD player at the back as the diff o/t for the Prgressive scan. Plug the cables to that nd the click on setup, where you can hardly see.. move to the 2nd option and select scan
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Televison & Video Logo
282 people viewed this question
Top Televison & Video Experts
