Smart car drivers door is locked and will not open passanger opens.
SOURCE: windows open by themselves when car is locked !
check out the alarm module under the drivers seat most likely its flooded if so check out the roof tub drains and if it is only the dealer can replace and recode module to the car
SOURCE: Audi a4 driver dood wont open
Enter car from left rear behind the driver and see if you can manually unlock it from the inside. Then use remote to test it.
SOURCE: the driver side door lock broke on my 98 jetta door want open
according to my partsman (who has had great advice for many years), you do not have to remove the door panel to replace the door handle which contains the cylinder lock. the handle is released with a screw which you can see when you open the door. you will need a starhead screwdriver or socket. A new handle costs around $40 at a parts store in my area. call around for a locksmith who will re-key your key to the new lock or use the key which comes with the new lock, your choice. i am in dealing with this also
SOURCE: 2008 chevrolet malibu door lock problem
You have a intermittent condition. To isolate the cause: 1.Disconnect the drivers door lock/unlock switch from the connector. Drive the vehicle and see if your random lock/unlock condition has stopped. If it has, replace the switch. If it hasn't:
2. You have a grounding problem or a problem in the BCM (Body Control Module) and should have a technician use a Tech 2 Diagnostic Link Tool to access the BCM computer to obtain any fault code data to help correct the condition.
SOURCE: CEntral locking problem drivers door, VW GOld PLus
Actually they area vacume/preshure opparated system.... now if fitted with this crazey system bear with me!!!!!
Open the boot, pull back the lineing to reveal the off side rear lamp cluster, underneath the cluster you will see a black box with a plug and a plastic preshure pipe going to it (this is the vac- air+ preshure pump and electronic control unit.
Now what happens is this the seal on the back light cluster leek rain water in after a while, and guess where it goes? Yes thats right all over and inside the box where al the electronics are! Fantastic ! any way solution is easy just take the box out....take it in the house open it... tip the water out! dry it out in the airing cubard or hair dryer e.t.c. put the lid back on thats it (GOODTHING REALLY SEEN THE PRICE OF THEM?) oh! forgot to say it is in like some grey polystirine in the car to stop it banging about!sugest you re seal the lamp unit with some RTV silicone sealer (Better than the manufacture seals) OH YES THAT BOX ALSO IS THE ALARM CONTROL TOO!
There you go Neil your all sorted!
