Question about Panasonic SC-MT1 System
Code FG61 Last week my system made an odd noise from the speekers and switched off. WhenI tried to put it back on, the code FG61 came up and then switched off again. Can anyone tell me what this means and can i get it fixed
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Dec 06, 2013 | Televison & Video
Motor noise threw my speekers
Check your ground wire and ground straight to the body that should fix the issue
Aug 15, 2013 | Car Audio & Video
1998 Isuzu Trooper won't charge battery. 3 alternators in the last year and a half and all get "burnt up" according to the mechanic. There is a 6 disc cd changer that doesnt work and makes odd noi
have you checked the wire that goes from alternator to the battery ,and see how many volts are going back to the battery. it maybe grounding off
Dec 14, 2012 | Isuzu Trooper Cars & Trucks
The monitor keeps making crackling noises
Try relocating the monitor to rule out external interference, if no the monitor will need to be checked for bad connections such as bad solder joints.
Mar 09, 2012 | Summer Infant 02100 2.5 inch Color Hand...
Passenger side thumping from engine & check engine light
Yes please keep me informed. It is odd that a big place like Goodyear would pull any nonsence. I would say more to the coinsidence theory on this one. Of course they hire sub contractors to do there mechanical stuff so who really knows. If the mechanic gets a salary and a commsion then anything is possible. You might grab the front of the water pump and shake it back and forth and see if there is any play in it. Your uncle will know where to do this. Its up by the fan on the engine. I am not saying you don't know to and i am not trying to insult your intelligence. Just making sure. The water pump should not move at all. If it is going out then under more pressure from the AC might cause it to make noise only sometimes. Just another thought. The Raz
Apr 17, 2010 | 1995 Buick LeSabre
N96 lock code
Have you tried the last four digits of your cell phone number?
The default code is 12345 if you did not change the code in the first place. Some times a good nights sleep or a warm shower might help you recall the new code you don't remember now.
Jun 22, 2009 | Nokia N96 Smartphone
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Panasonic SC-MT1 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
