My tv won't shut off with the remote or by the button on the tv. What can I do?
Have you tried unplugging the set for several minutes and then plugging it back in?
There is a separate circuit in the TV that turns the set on & off with either the front panel button or remote. The front power button does not switch the 110V directly.
The circuit could be either be a relay or solid state switch that turns on the main power supply.
It sounds like you have a problem with that circuit and you'll need to take the set in to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked
2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds.
4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds.
5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the
model, one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
I have an Akai 32 inch tv CT3216. Please help.
Thank you for help. It was great. I'll know what to do in the future if it happens again.
