Question about Kenmore Elite HE4 Electric Dryer
Clothes washing machine
Cycle dial will not advance on its own, just manually. Spin cycle will start if you open then close lid after water drains, otherwise must be done manually. Machine seems to work as it should, just that the dial has to kept going manually to get to end of cycle. Also, wash and rinse water turns quite a dark blue.
  • 3 more comments
  • Anonymous Feb 16, 2008
    the washing machine model # is 110. 20952992, serial # CK 0901042, and type 111.
  • imnothandy Feb 16, 2008
    imnothandy's model # is 110.20952992, serial # CK 0901042, type 111.
    fyi, it does not advance in any part of the cycle on its own. Thank you very much for all of your help and info!!
  • imnothandy Mar 10, 2008
    Me again! I have been manually advancing the **** to the different cycles when doing laundry, and did a load on a different wash setting (Permanent Press cycle instead of the Ultra Clean cycle which I usually use). To my surprise, the machine went thru the complete cycle from start to finish all on its own! Do you still think it is the timer? I have one on order thru Sears (160.+), but will cancel the order if I do not need it.
  • Gary Davd
    Gary Davd May 11, 2010
    PLEASE post your model number from the units tag you have this problem posted under an HE4 model but say you open the did an HE4 unit is a Front loader....after yo post that maybe we can help you
Ma laveuse ne spin pas ,elle senble glisser
Posted on May 01, 2008
  • 770 Answers
Fist off the unit is operating ok it was designed to only spin after the water is let out. by you opening the lid and closing it you have paused the machine (opening the lid) and started it back up This function is also built in the timer to pause the machine then go into spin.. The timer sounds like it has a dead spot in it. is this the only place in the cycle it does this ???? or does it stick and not advance say in the Agitate portion of the cycle?? there is a small timer motor on the timer that advances it it could be going out l. If you check that out with no luck the part # for the timer is 3954449 is is about $102.00 at www.sears.com it is $109.00 at www.apdepot.com the little drive motor on the timer is not a replaceable part the whole timer will have to be replaced
Hope this Fixes Ya
Posted on Feb 16, 2008
  • Gary Davd
    Gary Davd Feb 16, 2008
    If it wont advance on any part of the cycle then that little motor is shot you will need to replace the timer..
    Plz rate this help Thanks
  • Gary Davd
    Gary Davd Mar 12, 2008
    Yes just get it most likely it has a dead spot in it . This is the ONLY part in your machine that advances the cycle
Kenmore model 11020842990 series 80. had a severely unbalanced load in the rinse cycle. opened lid, rearranged clothes, would not start up again. Removed clothes to dryer, luckily most of water had...
when it went unbalanced the tub most likely broke the lid switch part
3949238.open the lid,on the right side of lid you'll see a strike,it goes into a hole and this is where the lid switch is,stick a screw driver into the hole,if you don't hear a clicking sound the switch is broke
http://www.youtube.com/watch?v=MFsvLiuTniU
Oct 15, 2013 | Kenmore 24032\24036 Top Load Washer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
