Question about Bose 3 2 1 GSX System
Get sound but no picture
I have a toshiba tv, satelite and bose321. The tv shows fine on colorstream hd1 but I only get sound from the Bose System no picture. Please help
  • 33 Answers
Plug the yellow RCA cable into the Video Out on the 3 2 1 and into one of the Video In ports on the tv. Make a note of which port you plugged into. Then change the input selector to that video port on the tv.
Posted on Feb 16, 2008
I have lost my sound from TV through the Bose Lifestyle 48 recently. All other sound sources work fine- DVD/CD, FM/AM.
Hello Sunny,
No TV model... came through with your
Bose LifeStyle home theater question...
I'm just going to mention that I have seen a couple of available configurations... depending on your signal source... BROADCAST, CABLE, SATELITE... (etc.)...
If it is Just your intention to source from the TV...
THERE (at the TV)...
It might be as simple as going into "menu" ... then move down to your "AUDIO" PROFILE.. and make sure your external speaker OPTION is showing "ON" (or "equipped")...
on your TV and making sure your PRIMARY volumes sources & destinations (Bose) volumes at acceptable levels... so as to not FRIGHTEN your neighborhood when the sound does come through)
No success ... comment me back with your TV signal source...
HMDI or optical outputs... (and does your AUDIO Work in STAND-ALONE on the TV... Now??)
If all else is working on the BOSE... I don't think we need to continue there...
Comment me back if you need... I'll be around!
Post comments... addendum
(I did say Menu... (twice))...
RESET , General:
This operation will clear all of your customized settings.
V... depicts the volume down button on your remote
(immediately above the "menu" button).
With the set turned off...Stand in front of TV.
At the right side on the TV set... locate the power
button on the right side...
WHILE holding down the V (on the remote)
Turn on the TV POWER button on the TV.
(The TV will turn itself off, then back on again.)
Then ... V (symbol) Release the button.
This operation will clear all of your customized settings...
I'll still be here... comment me back... if you need.
Hope it helps
ELSE ...
We need to move on to your PCBs
Jul 21, 2016 | Bose Lifestyle 48 System
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
I can't get my Bose321 system to power back up!
Put a stick of dynomite in it, End get a real stereo system
Oct 04, 2012 | Bose 321 GS series II
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
No picture, no sound, but has power light...any suggestions? thx in advance
Do this first:
1: Check the antenna/cable connections.
2: Press the TV/VIDEO on the remote control or the TV to view a signal coming from another device connected to your TV, such as a VCR or
video disc player. You can select ANT 1,
VIDEO 1, VIDEO 2, VIDEO 3, ColorStream HD1, ColorStream HD2, or ANT 2 depending on which input jacks are used for connecting the devices.
*Be sure you have the right source to view video.
Try the above and post back before I can say there is a problem with your unit. If you have the user manual it's a good time to get it out. If you don't have it let me know and I will give you a link to obtain it. Good luck!!
May 23, 2009 | Toshiba 50H82 50" Rear Projection...
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Mar 06, 2009 | Bose Lifestyle 38 System - white Theater...
Picture on my Bose Lifestyle 35 is jumping around
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
Bose 3 2 1 GSX System Logo
314 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
