Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
Sony kv-40xbr800 won't turn on, blinks 6 or 7 times
My Sony kv-40xbr800 won't turn on, then the LED on the front bezel blinks repeatedly 6 times (once in a while it blinks 7 times after attempting to turn the set on.) When it is starting it makes a popping noise right as the audio starts to kick in.
I've tried unplugging it for a minute to a few hours, that doesn't help.
It will turn on normally if you let it sit for a long time. We have been just leaving it on and it works fine. But, every once in a while we forget that it is broken and turn it off. It takes a few days of trying then it works again.
Otherwise it works fine.
  • 2 more comments
  • gooman80 Mar 09, 2008
    Have the same problem,it clicks like its going to turn on but dosent.
    have unpluged it allso this worked at first but now it seems like it wont turn on at all. LED allso blinks six times.
  • Pdawg2 Mar 14, 2008
    TV wont come on blinkd 6x and 7x does one in on mode and one in off mode. Tried sony solution unplug for 60 sec. didnt work, tried it again a few days later still didnt work. After being unplugged for about 2 to 3 weeks it know works. Would like to why and if it will do it again.
  • mcfin Apr 08, 2008
    Wow, was I lucky. The store had thrown in a five year warranty that I had forgotten about. The repairman took the board in and had the defective module replaced in less than a week. He said that the repair and labor would have run over $400 otherwise.
  • edouble8 Sep 22, 2008
    Do what I did. Look in your local yellow pages for any television
    repairman who is familiar with Sony televisions, in particular, one who
    has worked on these particular models.
    My local repairman felt confident that it was related to an IC power
    reg. (I don't know what 'reg.' means, he just wrote that on the
    receipt). I've looked through various web sites & I've become
    aware of D-board problems associated with this model(s). A D-board is
    essentially like a motherboard (just like in computers), and this
    particular circuit that is bad is like a little chip located on the
    board. I'm not an electrically inclined person, but at least I've done
    a little research before I hired this local repairman.
    Anyways, I had him replace the integrated power circuit (part # MCZ
    3001DB), which required removing the existing, soldered one &
    re-soldering the new one.
    It has been working w/o any problems since he replaced the part.
    Although it has only been 5 days since, again, the repairman was
    confident that was the problem & that it should last for quite a
    while (hard to predict really).
    The bottom only costed me $123, which included him coming over to my house instead of me lugging the impossible! It only took him approximately 30 minutes total.
    Anyways, do some may be lucky that it the cost of repair
    is significantly lower than buying a brand new LCD from somewhere...
There are two large electrolytic caps on the D board located on the same side as the hv xformer.
both caps are 1200ufd at 250v, replace C6503, it is futher away from the side of the pcb.
this is the part of the ac rectifier that feed IC6501 chip MZ3001D
cap size is 1 1/8" diameter and about 2" inches high.
my problem with 6 or 7 blinks, would go away temporarily after the tv was unplugged for 24 hours.
i verified the fix by attaching a 250ufd at 250v cap in parallel with the C6503.
the problem was corrected.
you must assume the cap is leaking, which leads to the intermittent failure.
parts and shipping are a killer, so i turned to ebay.
search ebay for "Electrolytic Capacitors, 1200 uF, 250 Volt, Snap in 2X".
as the only bidder, i picked up two caps for $3.99 + $3.50 s&h.
might be wise to replace both caps, C6503 and C6590.
bill wireman
Posted on Mar 10, 2009
My tv kept getting 6 blinking lights and sometimes 4 and 7 blinking lights. So I first changed IC504 (5v reg) and the caps near it C530 and C540. It turned on a couple of times and then it stopped again within 24 hours. then I changed IC5001 AND IC 5002. still no luck. then changed C6503 AND C6590 capacitors with (1500micro f 250V because local store did not have 1200micro f 250V) they were a bit bigger and did not fit so I used 16 awg copper wire and made about 1inch legs so they would reach. I also changed C6546 becuase I saw that black goo on it and firgured it wouldn't hurt to change. still no luck. Then I changed IC6501 with a spare I had that did not work. I replaced the original ic6501 and took my spare placed it in ic8002 and the tv turned on. It still is less than 24 hours but it is on. I am going to order two new IC6501 AND IC8002 and replace both and hopefully it will last. any questions or suggestions feel free to contact me at even if it is a long time from now I do not mind helping. Thanks everyone else for your help in figuring out a solution!!!!!!!!!!!!!!!!!!!!!!!!!!:)
Posted on Apr 13, 2009
Toss the Sony set and purchase a Panasonic Plasma. I have the same set with the exact same problem. Was told by a local repair shop that the high voltage module was to blame and that it is obsolete. I called the Sony repair center and they confirmed that the module was obsolete, but they can repair it for between $500 and $700. I set up an appointment with the technician and he canceled the appointment and never followed up to schedule another appointment.
Posted on Apr 06, 2008
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details,
Nov 28, 2013 | Sony Televison & Video
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Sony kv-40xbr800 blinks two times
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My sony kv-40xbr800 blinks 6 times, no video no audio, it wont turn on, whats going on?
The problem is on the 'A' circuit board. It is the IC504.Or, it is a low voltage drop or a short. Replace the "A" board. It is the front board on your right when you are at the rear of the set when you remove the cover. Look it up on the net. PS Don't touch the chassis while it is on...HIGH VOLTAGE !!!
Aug 02, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron KV-40XBR800 wont turn on
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony VEGA KV-40XBR800 d Board failure
sony kv-40xbr800.......doesn't turn on......standby light blinks 6 times....what might be the problem? it worth fixing?
Dec 27, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
7,214 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
