Try pressing the reset or off button for a few seconds. Failing that, unplug the printer for 15 min. Let me know if it works, if not, then I will guide you through other steps.
To align the print cartridges from the HP Photosmart Software 1. Load letter or A4 unused plain white paper into the input tray. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again. 2. In the HP Solution Center, click Settings. 3. In the Print Settings area, click Printer Toolbox. NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click Printer Services. NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button. The Printer Toolbox appears. 4. Click the Device Services tab. 5. Click Align the Print Cartridges. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then press the button next to OK. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again. The product prints a print cartridge alignment sheet. 7. Load the page print side down on the right front corner of the glass, and then press the button next to OK to scan the page. When the On button stops flashing, the alignment is complete and the page can be removed. Recycle or discard the page.
from user manual:: To align newly installed print cartridges 1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again. If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. .... 2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. 3. Press the Scan button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet Score the solution and download the manual if you need it
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model). Press the right ARROW repeatedly until the display window reads Maintenance. Press ENTER. Press the right ARROW repeatedly until the display window reads Align Print Cartridges. Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page Verify that the alignment was successful after the page is complete.
This could be a hit or miss but what does it hurt to try...
I had this problem with the color cartridge a while back. Worked tirelessly with HP support and somehow got it to work. Since it was on the phone and a while back, I fogot! Now is the time for the black cartridge. Same thing. Reading somewhere here about skipping the test I gave it a try and it worked.
- Unplug the printer for 1 minute (not sure if this is necessary but it doesn't hurt).
- Replug.
- When the "Press Enter to align..." message comes up, PRESS and HOLD Enter.
- While holding Enter, press Menu. The screen skips the test part and shows the date.
- Release Enter. Now you can print. Actually, I could print, you are on your own now.
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
well, what i did, and it seemed to work, in the short run anyway.
i took and threw my hp in the back of a waste management truck,
then i called amazon.com and i ordered a new epson printer,
