ERROR CODE 34 on Mitsubishi TV
I have a mitsubishi 57inch DLP, the bulb was replaced after only 2000 hours. Red light went on again, they replaced the bulb within 2 weeks a 2nd time. Red light on AGAIN and its been 2 days. I reset the TV and TV worked for one day and now red light on again and TV not powering up. Tech guy showed me how to read the error code if I had any problems. I am getting 34. Does anyone know what that means.
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Posted on May 04, 2008
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red light for bulb indicator stays on.
You need the V26 DLP power PWB repair kit. You can get it at the following link under the repair kit category and it has complete instructions with the replacement capacitors.
Jan 15, 2009 | Mitsubishi WD-62526 Projection TV
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
496 people viewed this question
Top Televison & Video Experts
