Question about Lexmark X1270 All-In-One InkJet Printer
Paper feed drags the paper to one side - Lexmark X1270 All-In-One InkJet Printer
  • 1 more comment
  • cmaifeld Feb 21, 2008
    Paper feed has only one roller on the left and therefore pulls on that side of paper and not the other. Works well, therefore with envelopes and substandard-sized paper only.
  • thenight321 Feb 24, 2008
    it does the same thing with the paper it pulls it to one side
  • Lolo21 May 15, 2008
    My printer was working fine, and then one day when I went to print it started dragging paper to the right and keeps getting stuck.
    This seems to be a design fault that Lexmark needs to correct.
    Rere
Wow - I have been frustrated for the last 2 hours and finally turned it over and shook it and had a pen cap fall out!! now it works fine. Thanks for the help!!
Posted on Sep 08, 2008
As crazy as it sounded,,,,,I picked it up to shake it and low and behold...out came a pencil. So it is working better now. It is still just a tad bit crooked, but it is working now. When all else fails, shake it!
Posted on Jul 26, 2008
Following the advice from above, I picked up my Lexmark Z735 and shook it. Although I didn't notice anything falling out, it worked fine afterwards.
Posted on Jun 10, 2008
    Problem Solver:
  • 3 Answers
I found a thumb tack too and now it works fine. Weird!
Posted on Feb 24, 2008
  • 4 Answers
I finally cleared the problem by picking up the printer and shaking it--a thumbtack fell out and it works fine (better anyway) since.
Posted on Feb 22, 2008
    Problem Solver:
  • 3 Answers
This seems to be a design fault as the same thing always happens to me whenI used a Lexmark. You could try putting something next to the paper to level it up. (i.e strip of cardboard perhaps)
Posted on Feb 16, 2008
Hi! My name is Roy Napier and I have couple of problems for which I would like your advice. 1. On some occasions my print-out has faint extra "ghost" copies of the text etc printed plus the colours seem to...
My first suggestion to you is to remove, clean, shake, and reinsert the ink cartridges, then allow the printer to self align. Follow your manufacturer's recommendations for removal and insertion of the cartridges.
The dragging of colour that you mention is most likely attributed to the rollers which feed the paper. If one is dirty, it will affect the paper's print quality. The way that I suggest to fix the problem with dirty rollers is to obtain a long, continuous piece of brown paper towel (utility towels, like you find in factories) and insert the end of the paper into the multi-purpose feed, then feed it into the printer for a few seconds.
Once the paper towel has fed into the printer, extract the paper manually by pulling on it in the opposite direction of feed. Repeat this process a few times and the rollers will be clean, and the color scrubbing problem should cease.
Dec 29, 2009 | Dell 3100cn Laser Printer
Paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
The paper stuck when i want to print
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 01, 2009 | Office Equipment & Supplies
The paper doesn't feed into the printer. help!!!
First open the printer , its due to paper fibre on the sensor or some part of paper lying in printer Clean the printer and the Sensor , and then try again
Anirban
+919434878250
Apr 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper does not feed straight. It seems to drag on one side
If the paper is in the Feeder Straight, then it's a faulty feeder. My CX9400Fax did the same thing out of the box. Epson replaced it and paid the shipping.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Paper goes in squint drags to one side and jams
In my experience the usual reason for this is something (obstruction) in the paper feed. Make sure you have a really good look right down inside the paper path as quite small objects will stop a correct feed. The fact that it is one side makes me thing something is in there. I have serviced printers before with coins, paperclips etc that have found a way in.
Nov 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper feed
Hello Dear,
Both the printer has something stucked in the ASF Auto Sheet Feeder Assmbly of the printer try removing it your problem will be solved but if it persists you need to take it to the Canon Care get the printer serviced.
Regards,
Joseph
+91 9352008418
May 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
it sounds like to me that you do not have the paper guide set on the back of your printer if it is not set correctly paper will get pulled from one side. Also I would check to see if something has not been invertantly droped down between the roller and the paper support rollers. Another problem that i found is if you do not use a lexmark printer for some time the ink as well as the shuttle can get gummed up causing it to push the paper instead of gliding over it.
Jan 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
