Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
It is not spinning but will fill and empty water leaving clothes all wet
  • 1 more comment
  • papo128 Feb 16, 2008
    no, we haven'y. where is it located?
  • somuchfree Feb 19, 2008
    Switch works. It makes sounds like something is spinning inside. the tank does not rotate by hand, either. Is it fixable?
  • Gary Davd
    Gary Davd May 11, 2010
    have you checked the lid switch??
  • 770 Answers
You will need to unplug the unit... pull it a little bit away from the wall (4"or so) look over the top console you will see 2 phillips screws on the end caps going stright down there are plastic retainers to hold the screws in place removed them just enough to open pull forward on the console flip it up you will see the lid switch on the right side
Posted on Feb 16, 2008
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My railroader 7kgfills with water but won't start even when on spin cycle it will fill and empty but won't wash or soon please help me
faulty timer electronic control board
water level valve faulty ..too much water
drive motor worn
overloaded past 7kg with wet clothes and water
Oct 31, 2016 | Washing Machines
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
