My whirlpool washer stopped during the transition from wash to rince.
Water did not drain out of washer. Timer is ok. Motor hummed in wash range but agitated when turned on and off several times. Would not pump water out when manually selected to that position . Wife reported a leak at front edge of machine. Suspect foreign object in water pump, bad pump, or motor. Can you help.
zepher4@hotmail.com
  • lowell302 Feb 17, 2008
    After removing pump from washer it appeared undamaged. Impeller blades looked good and no obstruction. Motor runs but is noisey in wash mode with out pump installed and only hums in pump mode.
  • 770 Answers
I say bad pump !!!.....check your email
Posted on Feb 16, 2008
  • Gary Davd
    Gary Davd Feb 17, 2008
    see the ratings by my comments right there
  • Gary Davd
    ok looks like you have rated me Thanks for trying guess you are on your own now ...GHEEEZZZ Some people
The washer will fill up with water but it wont start washing or drain or spin you hear a humming noise then everything stops. Then in about 5 mins it will hum again then stop again
If the washer will not agitate, spin or drain it's a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction. The reversal of the polarity is controlled by timer contacts 7 and 14.
Most likely it's a timer or loose wire connection.
Jan 22, 2011 | Estate ETW4400VQ Top Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
My washing machine fills up with water, but want start washing after it fills. I can turn the knob to rince, spin, and drain, and it works. What is my problem? Is the timer ok?
Yes, i do agree, the timer will be the problem. Everything runs through the door limit to start then through the pressure switch then to the timer. The fact that you cag get the motor to spin when forwarding the timer means the pressure switch must be ok.(im taking it that the water switches off when required water level is reached. Also, if water does not switch off, make sure the drain pipe is the same height as 3/4 the tub height
Aug 20, 2010 | Frigidaire GLWS1233A Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Dec 25, 2009 | Whirlpool Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
    No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
    Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
    Whirlpool AWO3761 stuck mid-cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    90 people viewed this question
    Top Washing Machines Experts
