Question about D-Link AirPlus DI-524 Wireless Router
Internet connection Main computer will not connect
  • BtoB Feb 23, 2008
    The prblem was solved by checking settings back to the on position
    Scholar:
  • 89 Answers
I had a similar problem with a TP-LINK wireless router. I reset the router to default by pushing a paper clip into the reset hole on the back of router. I also unplugged power to router before resetting. Hooked Internet cable back to DSL Modem and connect to internet with a browser on main computer. I then plugged main computer cable to router. Then router to DSL modem. While I'm doing this there are messages "The cable is unplugged". Then the connection is Shown reconnected. I then was able to browse and I then was able to enter 192.168.1.1 and a Password message appears. Yous would be D-LINK for the SSID. The Password and ID would both be "admin". You can change these for security purposes. Hope this Helps. Thanks
Posted on Feb 17, 2008
  • 28 Answers
If you are able to connect on other computers, then check the ip address of your main computer.
steps to check ip...
1. First connect your router and your computer with ethernet cable.
2. Click start->run>type in the run box as "cmd" without quotes..
and then click ok.
It will take you to command prompt screen...there you will find a cursor flashing Type next to that as ipconfig and then press enter...
It will give you the "ipaddress' of your computer and "default gateway" i.e. the ipaddress of your router...
check if you get this and then let me know
Posted on Feb 16, 2008
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
No internet connection
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Click here for step by step instructions
Dec 03, 2009 | Computers & Internet
I hooked up wireless internet and my main coputers internet isnt
check the connection or from where u r connected the wireless connect just see that the problem will be solved ok
Aug 22, 2009 | 2wire 2700HG-B Router (2700HGB)
Second computer has no internet connection
na kuwe aku wae bingun kowe ngomong opo to...!!
Aug 11, 2009 | Computers & Internet
Can connect to router, but not to internet
Is the main computer connected to the router or to the internet directly? If it is a cable modem for the internet, make sure you turn that off, as well as the router, and connect the cable modem to WAN on the router and put the modem on first, then the router. Connect the computers, xbox, etc to the router
Jun 06, 2009 | Microsoft Broadband Networking MN-500...
Stick is connected but having hard time connectinfg to internet u
Don't you have a Wireless Router ?
Since you can connect both machines to the Router by Wireless.
Jan 15, 2018 | Ashton Digital WRUB-2011i 802.11g/b...
Moved network
You should be able to switch the two, however, if this requires a network to be set up in order to run both computers through the same router, I recommend having someone do this for you.
Aug 22, 2008 | Acer Aspire 3680 Laptop
Additional computers & internet access
You can do this. Identify the ip address of your main router. EXAMPLE: If your main router has 192.168.1.1, you can connect the cat5 cable from your main router to the INTERNET PORT of the NR041. Set the NR041 ip to 192.168.2.1.
JUST MAKE SURE THAT THE IP ADDRESS OF THE TWO ROUTERS ARE DIFFERENT.
You can then connect the 3 computers to the NR041
Good Day
Mar 07, 2008 | Linksys (NR041) Router
Wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link AirPlus DI-524 Wireless Router Logo
65 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
