Question about Hotpoint Aquarius WMA42 Front Load Washer
Does not spin and rinse properly
My washing machine is Aquarius WF 321 hotpoint. during the washing period, the machine does not spin and rinse properly. When machine completes washing, but clothes are found more wet. Previously they were more dried.
  • 2 more comments
  • Anonymous Mar 27, 2008
    Suds remain after final spin. To test if the soap has rinsed out I placed a few items in clear water in a washing up bowl and the water became very sudsy. I have cleaned the soap drawer flushed the machine out with a hot wash and no detergent - all to no avail. Please help.
  • ditdit May 18, 2008
    I have Aquarius wma36 (7yrs old) its just stopped spinning, but all the lights on the programmer were on. Surely if motor gone, it would not wash atall?
  • Anonymous Mar 12, 2014
    how do i reset the washing machine?,it washes the clothes but does activate to rinse en dry
  • Anonymous Apr 01, 2014
    the machine washes but does not spin and dry.
  • 96 Answers
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Posted on Feb 17, 2008
Hotpoint Aquarius 321 stuck on spin with all lights flashing
you have a faulty control board unplug the machine take of the rear cover ????
before you take any wires of ''''''''take pictures
then take of the wires
look at the control unit see if you can see any damage
Jan 12, 2014 | Hotpoint Washing Machines
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf 000 will wash but wont rinse or spin any suggestions please
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear....
May 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do I open the filter on a hotpoint aquarius WF 321 1200 spin washing machine?
there should be a hatch on the front at the bottom right hand corner! open the hatch and you should see something that looks like a dial turn this anti clockwise. if it does not turn you will have to apply pressure. this could possibly break the componant! don't worry this often happens they are easily replaced from your local domestic appliance repair centre
Oct 16, 2009 | Washing Machines
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
536 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
