Question about Envision EN-7220 17" Flat Panel LCD Monitor
Monitror keeps cycling through on-off
When I boot up the PC the monitor turns on but then it clicks off automatically in a moment, then after a few seconds, turns on and off again. It keeps cycling through the on-off stages. When it turns on- i can see the Windows log on screen momentarily. so I know Windows is booting up correctly. (Windows XP) Once in a while (I have to try and switch it on-off several time from the main power switch) it stays on and works normally. But as soon as it is turned off again or the system reboots again it starts on-off cycles again. I have tried it on another pc with the same results. one if them has on board video, the other one has a video card. can someone help please? Same problem but, but my monitor is and en7220.
Found one of these in the dumpster at my shop today. Had the "stays on for 3 sec then turns off" issue. Problem is the bad batch of electrolytic caps of a few years ago. 2 on the power supply board were visibly swelled up (470u/16V and a 1000u/16V). Replaced them both - it's fixed. Cost 50 cents.
Posted on Sep 05, 2008
  • vgreen20 Sep 05, 2008
    oops...I see in another thread that someone else has alredy posted how to fix this...sorry.
I think this is a problem of bad capacitors. I am having the same problem, but it never stays on, it just cycles on and off, only staying on for a split second, showing "ENVISION" in white. I might try to replace the capacitors if i can find the right ones.
Posted on Mar 17, 2008
  • 22 Answers
My suggestion is try to contact an expert technician of your monitor maybe it has loose contact inside.or before contacting anyone else try to boot your pc in safemood, if it runs smoothly then your monitor cannot support the screen resolution of your pc.
Posted on Feb 20, 2008
2 Suggested Answers
SOURCE: Monitror keeps cycling through on-off
We have a number of CTX monitors with failing power boards dropping out the back light rendering it black or appearance it is dead. Given the number of them we have seen it would suggest there is a possible weakness in the design and replacement is the only option
Posted on Sep 29, 2008
How do i fix my iphone without itune and it is disabled
Your iPhone may occasionally lock up and become disabled,and Can not open it, it's possible to correct this problem with the two buttons built into the Mobile.
Instructions
  • Press and hold down the circle button, located below the touchscreen, and the small button at the top of the screen. Continue to hold these buttons down as the iDevice turns off.
  • Wait a few moments, then press the circular button. After a few moments an Apple icon loads onto the screen. This performs a boot cycle that takes several moments.
  • Slide your finger across the "Unlock" option when the Mobile has finished booting. The main screen appears, allowing you to again use your iPhone Disabled .
Oct 16, 2014 | Apple iPhone Cell Phones
My monitror display is " no signal output analog"
Pls change the resolution of your system.
Apr 29, 2010 | AOC 19LVWK LCD Monitor
Monitor goes off after a few moments when powered up, you can close it and open back up and it comes back on for a few moments
click the start button and locate the control panel, then once inside the control panel, look for Power (can't recall the exact name).open the power options and locate the monitor or video adapter, then next to those will be the option to select a time limit before the monitor turns off.
Mar 01, 2010 | Dell Latitude D600 Notebook
My Dell optiplex 170L keeps turining off and then
Possible that it's caused by a faulty hardware or a computer virus on your computer. For us to isolate the issue we must start troubleshooting with the hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. If all else fails, restart the computer and keep on pressing F8 before the window welcome screen comes up - to go to advanced boot options
10. Boot to Safemode
11. If you are able to boot to Safemode
12. Login as administrator
13. Click start
14. run
15. type msconfig then press enter
16. click on startup tab and click on disable all button at the bottom part
17. Restart the computer and let it start normally
18. if the same thing happen, boot to safemode again
19. Login to administrator again
20. Right click my computer
21. Click on properties
22. Click on Advanced Tab
23. Click on settings button under Startup and Failure
24. Uncheck the Automatically restart under System failure
25. Restart the computer in normal mode
26. Tell us if you see any blue screen error, if so, post the error here
if all else fail, your operating system needed to be reinstalled and you should have the cd for the operating system if it's XP or Vista or Windows 7.
Jan 08, 2010 | Dell OptiPlex 170L PC Desktop
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Powersave problem
If you are using a desktop computer, chances are that you don't want the computer to go to sleep automatically. This is even more the case if you are running Vista in a virtual machine for testing purposes.
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link
Then click on the Power Options link:
It will disable automatic sleep mode, but will still turn off display.\
You can click on change plan to disable.
If you are using XP than.
Open control pannel-> click on power option -> keep turn off monitor setting to never.
Feb 10, 2008 | Compaq Evo D500 PC Desktop
I also just recently started having this problem. If you look at the power brick the power indicator flashes on and off with the monitor. I think that the power brick is bad. I switched to a different monitor and the computer works fine. The en-9110 cycles on/off with or without a computer attached. I contacted Envision about an RMA.
Oct 16, 2006 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor turning itself off
It sounds like the problem is with the computer's video adapter settings. It is very likely that the monitor cannot handle the settings. If you boot into safe mode, can you see everything? If so, then the normal mode settings are too high. Safe mode defaults to the lowest possible settings (thats why everything will look really big) Try turning down the resolution (Right click on the desktop, select properties, go to settings tab) to the lowest possible setting, and then slowly try turn them back up again until you can find the maximum setting the monitor can handle.
Oct 05, 2006 | NEC Mitsubishi Diamond Pro 730 (White) 17"...
Envision EN-7220 17" Flat Panel LCD Monitor Logo
332 people viewed this question
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
