Question about Canon PIXMA MP160 All-In-One InkJet Printer
Need help with printer dell 942 paper jam
My printer say their a paperjam and their no paper in it how do i fix this
canon pixma MP460 false paper jam.
I tried doing as was suggested for the Dell but no luck
  • mary pooh Feb 20, 2008
    thank you but nothing worked so am returning it to the shop
    Scholar:
  • 160 Answers
Power off the Printer
Un Install the Drivers of the printer
restart the system
re-install the drivers
if the problem continues
1. check the printer data connector
2. Check the correct paper is loaded
3. Check the colou catridge status
Posted on Feb 16, 2008
Paper iam
open the printer back cover and remove paper from it
May 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 Paper Jam
this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Feb 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam in a mp460 printer(canon)
clean up the roller that picks the paper up.
Jan 30, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp460
check for obstruction and paper thickness lever on the printer and try printing again.
Apr 14, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Mp460 canon all in one
Same problem .Alarm light on and paper jam advice on the screen. No paper there...
Apr 08, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Nov 27, 2007 | Dell 942 All-In-One InkJet Printer
False Paper Jam
I have a problem with a canon printer MP460 its saying I have a paperjam but there is no paper to be seen cartridges move back and fore manually with ease please help
Nov 04, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
