Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Not spinning it fills with water but does not spin and leaves clothes very wet
  • 1 more comment
  • papo128 Feb 16, 2008
    yes the water pumps out
    thanks so much where is this switch?
    I think so.
  • 770 Answers
Does the water pump out ok?
Posted on Feb 16, 2008
  • 3 more comments
  • Gary Davd
    Gary Davd Feb 16, 2008
    ok set it to the spin cycle on the timer.. with the lid open i want you to take a pen and press down on the lid switch to see if it goes into spin let me know not too much pressure on it if it is quiet you should hear a click when the switch closes
  • Gary Davd
    Forgot to ask the Agit. cycle works ok ??
  • Gary Davd
    look on the lid you should see a plunger (plastic) see where that closed to on the rim of the machine right side you will see the sw.
    PS: if you dont this model may have the hidden lid sw. plz let me know
  • Gary Davd
    you think so what??
  • Gary Davd
    I looked up your model it does have the hidden lid switch... you will need to unplug the unit... pull it a little bit away from the wall (4"or so) look over the top console you will see 2 phillips screws on the end caps going stright down there are plastic retainers to hold the screws in place removed them just enough to open pull forward on the console flip it up you will see the lid switch on the right side
Dear Master_Tech and Fixya folks,
You saved me money and time. You gave me the courage to go in there with a phillips screw driver and investigate, like you say in your comment. I found the hidden switch on the left, it is an Ark-les 1/2 HP, 125V, 60Hz, 250V, 50-60 Hz PN 8318084 that looks like a little plastic box that has a top lid and when I took the lid off I saw the little electro-mechanical relay switch (I had the machine unplugged while opening it up). And when opening and closing the washer lid, I could see that a black plastic knob coming from below moved in the middle of the relay complex. To make the story short I fiddled with the outside of the switch box and I noticed it was wiggling when moving the washer top loading lid up and down, My conclusion was that the switch was okay, but it was sitting very loosely and so it would not sense the lid opening. Now I have it secured to the machine by placing a screw between it and the machine hole where it sits. That, believe it or not, keeps it tight to the machine and allows it to sense the lid opening and closing. I covered the panel back up and everything works fine. Well that screw may come loose in some future due to vibration, so it is a temporary fix. But at least I can now finish the load that I had started. And maybe a few months more. I know the problem though if it stops working again, and how to fix it.
Thanks to all of you who do this,
Jairo
Posted on May 22, 2008
  • Jairosoft May 22, 2008
    The above solution I posted was for my own washer. I am no technician. My Whirlpool is a Ultimate Care II LSQ9030PQ1 Serial CS0736248 made in 2005. So if you have a similar machine, like the Master_Tech suggested, take a look at the hidden lid switch that is under the panel. And in my case the switch was okay, but it was not switching because the base where it was fastened to was allowing it to move as the lid moved and thus not allowing it to sense that the lid had moved. In other words the switch was floating in air. So by securing the switch to the base, I was able to get the switch to switch. It was a purely mechanical issue.
  • Merle Stone
    Merle Stone Feb 02, 2014
    Had the same problem. When i closed the lid i heard a double click from the switch. The plastic clip for the lid switch had cracked and was allowing the switch to move, thus disengaging. Put a new switch in and the machine runs like new!
jsrock516
  • 5911 Answers
SOURCE: Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Posted on Apr 29, 2007
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
Posted on Aug 04, 2008
MNTECH
  • 1543 Answers
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
Posted on Oct 27, 2008
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
  • 250 Answers
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
813 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
