Question about Neff 23 in. T1443 Electric Cooktop
Neff Hob I have activated the safety lock on my touch control hob and don't know how to switch the lock off again. Can you help?
  • 3 more comments
  • Anonymous Jun 15, 2008
    locked
  • philada Jun 15, 2008
    I'v locked my hob t4344 how do I unlock it please
  • illyb Jul 24, 2008
    Neff 23 in. T1443 Electric Cooktop lock activated how do i unlock
  • highdee21 Dec 17, 2008
    I spilt hot water on my hob and when I wiped it up I acciendently activated the lock and I can't get rid of it!
  • Gary Davd
    Gary Davd May 11, 2010
    Need to post the model # so we can pull the manual
Hold the power button for a few seconds
Posted on Nov 01, 2008
    Problem Solver:
Hi
Wondered if you could let me know if and how you deactiviatedthe lock on your cooker as I have done exactly the same. Thanks
Fiona
Posted on May 04, 2008
2 Suggested Answers
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Jun 18, 2009 | Cooktops
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Hob lock
gud day,the key symbol is the lock try to unlock the unit by touching the sensor,or check the manual how to unlock.
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff 23 in. T1443 Electric Cooktop Logo
1,807 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
