Question about Freezers
Engel portable freezer model 5K-511n
The freezer runs ok, the thermostat switches the motor on and off but the freezer doesnt chill down. Any ideas please?
Thanks Paul
  • 417 Answers
Check that the door is closing fully and that the door seal insn't damaged in any way.
Thanks J
Posted on Feb 16, 2008
The relay and thermostat was changed changed .the chest freezer is only chilling not freezers it was put on 12 hours . Please assist
if the compressor is running for a long time, then Dehydrator filter filter is pluged or ther is a leak. i would go for the filter first,
Nov 18, 2016 | Freezers
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Freezer contents thawed, freezer cuts on but only runs a few seconds and cuts back off
Compressors do not usually shut down. Either there is a power interruption to the motor caused by the power switch or thermostat or the motor has developed an internal short whereby it uses excessive power causing it to overdraw/overheat and have the clixon circuit shut it down.
Jan 20, 2014 | Frigidaire Freezers
I have a baumatic fridge freezer whch appears dead the plug fuse is ok and the electroic panal has been tested ok any ideas
Hello, Kindly check below matters on your freezer:
1. Compressor for defective. Please check the sound compressor, if still normal check the refrigerant . Please top up the gas if needed. If it is totally dead, you need to replace it with new one. 2. Thermostat for malfunction. This part will trigger the compressor to running and stop. You can test its operation while your compressor working normal. If your compressor is defective, the thermostat will not work. So please fix the item #1 before you go the latter item.
Regards,
Feb 02, 2011 | Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Fridge freezer freezer ok fridge warm willnot chill
dear sir/madam
i think there can be possible low gas problem it,s naturally if in your freezer there is low gas then it,s coil get warm. it,s coz of low gas so please contact to your service technician for find out leakage and brazing it and then refill the gas. i hope after that your freezer will work well.
thank you
please vote!
Aug 30, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Freezers Logo
91 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
