Question about Maytag Neptune Washer
Too wet after machine done
Hello, can you help me sovel this problem , my maytag washing too wet after sping stop, i mean it complet finish wash, but water still, i try rain only , but not work out,
  • Gary Davd
    Gary Davd May 11, 2010
    plz post your model number so i can help you
Maytag wash machine MAH8700AWW
Posted on Feb 16, 2008
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Regards
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
When the cycle is done my clothes is still soaking wet
Hello becca_m2012 ,
Is the machine a FAV6800A or FAV9800A. If it is one of those models are you failing in Spin Cycle of the Wash Cycle with a dC or Uc error code to the display? Lets nail down the model number and I will try to point you the repair path......Rich
Nov 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load washing machine
Have you checked the filter, it may need emptying/cleaning out. If you take bottom front panel off you should be able to see it -- I think it's toward the right.
Nov 08, 2008 | Frigidaire FTF530FS Front Load Washer
Maytag wash
it is spinning , but not dry
Feb 16, 2008 | Maytag Neptune Washer
Washing Machines Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
