Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener
the light will not go on when door is activated from remote or switch mounted on wall in garage.
I thought the light was burned out, bulb was replaced still not working, made sure bulb was ok light will not go on.
  • fordydan Feb 23, 2008
    I have the exact same problem with 18 yr. old sears unit.
    Scholar:
  • 143 Answers
Unplug the unit and look inside the socket. there is a copper lead you can bend up as it might not be getting a good contact. If that is not it you can start by replacing the socket itself from the manufacturer. If that does not do it then you will have to replace the logic board. Whether you reair or replace get a surge protector on this unit 900 joules or higher. Thanks BB
Posted on Sep 03, 2010
Why door is opening without being activated by remote opener or inside garage opener;something is activating the open/close command;ther is nobody around or a neighbour that may interfere with his doo
I had a similar problem. I discovered the illuminated door bell switch I used as the inside door control would activate whenever the wall on which it was mounted had a heavy vibration from door slamming or thunder. Could this be your problem too?
Nov 10, 2014 | Building Materials
My panel in garage blinks on and off and I cannot open the garage door from my car
Most of the time, that means someone has accidentally activated the Remote Lock Out feature on the inside wall mounted door opener switch. Check your Owners Manual for instructions on how to deactivate this.
Feb 18, 2011 | liftmaster Garage Door 1/2 Hp
No power to wall mounted door switch need wiring diagram
Wall mounted door opener remote should get power from the main console once that is powered up. If you have wired correctly onto to the wall mounted unite and onto the main console and upon powering up the main console there is still no "life" on the wall mounted unit, I would check if there is actually any current coming it. You can easily do it with volt meter (Harbor Freight tools have a very good one for $7 or so). If no active current, call Chamberlain.
Oct 05, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
I have a door with two buttons and remote but only
On the wall control with the flashing light press and hold the button with the lock icon for 3 seconds and release.
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
I think I've accidentally activated the lock feature...
does logic board on motor have a small pushbutton or dip slide switches? If pushbutton, push it for 10 seconds. let do. panel light stop blinking? Unit somehow got into lock mode, even though you do not have lock button. If this has stopped light from blinking, you now have to code remotes and or keypad back in. Push the little buton for 1 second and push a remote. Light bulbs on unit should blink. Take next remote (or keypad) and repeat this sequence for each one. Let me know. If you have safety beams, liftmaster should help you. w/o beams they will not support.
Feb 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
153 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
