Washing machine leaks
When I turn on the washer it works for a few seconds then stops and some water leaks out the front on the bottom of the machine. It'll start again and then stop and do the same thing.
  • 770 Answers
You pump is leaking most likely you will need to remove the cabniet to check this and run it with it off to find out for sure
Posted on Feb 16, 2008
Bauknecht wak 7508
There is a filter on the drain pump. You should clean it out and see if that is the problem. You can take the bottom panel off the front if this is a front loading machine. If not you need to lay the washer down so that you can see the bottom. Be ready for lots of water! The drain plug is large and it unscrews.
Apr 11, 2014 | Washing Machines
Leak around the door seal
the seal might look ok but don't forget the seal could crack on the bottom, any time the washing machine stops and the water settle
there's more water at the bottom half so the bottom of the seal takes more abuse. so I would replace the sealer and if you can buy a little thicker one.
Feb 07, 2018 | Samsung WF218ANW 4.0 cu. ft. High...
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
WATER COMING OUT FROM DOOR AND DRAWER
On this washer  the seal was replaced ?Did it stop leaking after the seal was put in ? Front load hatch on this is in front area located on the bottom(base).Remove the front  to gain access and you can now reach the pump and  look for any blockage.After  you have found and removed the blockage,run the washer again and if any water leaks remain call your local  servicer .You may have a bad front boot (seal) or its just loosened and it need to be re- tightened.Any water leak should be repaired ASAP so you dont have even more damage to the machine and your home.If the repairman cant stop the leak on his first visit than have the Boot replaced on his second visit.
May 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washer machine
Due to gravity if there is a leak it will be at the bottom, it could be a few things ie. door drum seal shaft seal a leak can be hard to find from here sorry
Nov 12, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
