Internet connection I cannot connect through my main computer. Can you help me trouble shoot. My name is Barry
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 39 Answers
So you have your computer wired to a router, isn't it? Try opening the CMD and input ping 192.168.1.1 (this is the default address for a router, if you had changed it for some reason then you should type ping 'default address' ) and you should see something like "reply ...". If you see something like "request timed out" then reset the router to factory defaults. Try pinging again your router, if you still see "request time out" then theres a hardware error on either the computer or the router.
Hope this works!
Posted on Feb 16, 2008
Ok, here's the issue I'm having. I have my regular computer in one room. I got a new pc for another room. I was trying to hook up the Belkin wireless router too it, and something isn't working...
the problem is likely you need to load up your computer's wireless manager- for instance, is there an icon that looks like a fan or a staircase? that would be the manager for your connection. At that point you should be able to setup the connection w/ the right wireless key/passcode in the pc and have all the wireless issues resolved (basically you'd be looking for something like Intel Proset, Dell Wireless Utility, or other utility/manager (it will usually have "Wireless Utility" in the name somewhere... makes it easier to find!)
Jul 17, 2011 | Belkin F5D7234-4 Router
Basically,when i try to access the internet using the wireless connection,the laptop tells me that connections are available .Then when i try to connect to access point,it takes some time and then tell me...
Usually the trouble shoot should fix your problem but my case using the same model, I had to turn off the wireless switch in the front and turn it back on. Then I needed a reboot. I had a Macbook on the side and had connections to the network but no internet connection was found. I later discovered it is the modem that was causing trouble to the 2 computers. So rebooting your modem by turning it off and on again should help. It did help in my case. Good luck.
Apr 10, 2011 | Lenovo G555 156 160GB Black Hard Drive
Printer says i'm not connected to the internet; then says status needs trouble shooting
connect your computer to internet through modem
your computer need send some troubleshooting file to HP support center through internet
Feb 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have a d-link extreme g attached to a cable modem; the d-link is set for wirless. I can pick up the d-link on my ipod and laptop, however it only provides local access; no internet. I've tried everything...
I'm sure you have tried most of these steps but I'm going to list them any way so we have a complete picture of the trouble shooting process.
If your only getting local access that indicates that the router is broadcasting the wireless signal but unfortunately there is a connection issue between either the modem and router or the modem and the internet service provider. The first step is to verify that your modem is online with a good connection. If you have a working internet based phone than your in good shape. If not than you will need to research the light patterns of your modem or bypass the router to determine weather or not you have a connection to the ISP. The first step in trouble shooting a connection issue between the modem and router is to disconnect the Ethernet cable from the modem and the router than reconnect it. Make sure that the cable is connected to the correct ports. Next you will want to power cycle the computer, modem, and router. To do this you will need to shout down the computer and disconnect the power cables from both the modem and router. Allow all devices to remain off for 2 minutes. Plug the modem in first. Wait for the modem to establish a connection with the internet service provider(ISP). Depending on the type of modem this can take up to 5 minutes. After a connection to the ISP has been made reconnect the power to the router. Wait about another 2 minutes for the router to establish a connection with the modem then turn on the computers in the home. From this point you will need to retest.
If you still only have local access than there is a good chance there is an issue this either the Ethernet port on the modem or router. To trouble shoot the Ethernet port on the modem you can bypass the router and power cycle the modem and PC again. If the PC has no access wile directly connect to the modem than there is an issue with the modem and will need to be replaced. The good news is that most internet service providers will replace the modem for free. If all the trouble shooting steps above have failed than you will need to contact the router manufacture directly.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My modem keeps dropping connection. I have called my ISP and they say everything is running just fine. It happens when i am playing counter strike source and i start lagging badly and all of the sudden my...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. The first step in trouble shooting this problem is to wait for the internet to drop off. As soon at this happens go to your modem. If the top 4 lights are not solid green then the the modem is losing it's connection to the internet. This can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. If the modem drops the connection I would recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Now if when the connection drops the modem still has access than the issue is most likely with the router or PC. If more than one computer loses it's internet access than you can rule out the computer as the issue. At this point I would have to recommend bypassing your router for about 48 hours. If the issue does not return than you know the router was the source of the problem.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Occasionally, the power light will blink slowly, and no other lights are on, and there is no connection. Disconnecting the box completely and reconnecting, and powering up solves the problem. What is the...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main cable line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. Since we know that the connection is being dropped at or before the modem I recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Your issue can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. Most commonly this will turn out to be a bad modem.
Aug 27, 2010 | Arris SURFboard SB5120 Modem
Internet becomes slow or stops working
Aug 18, 2010 | Arris SURFboard SB5120 Modem
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found. i keep getting this massage when i try to brows the net
When you type any name, e.g, 'www.google.com', your computer "talks" to a DNS (Domain Name Server), which translates the string 'www.google.com' into at leaset one IP-address:
Addresses: 74.125.155.103, 74.125.155.106, 74.125.155.147, 74.125.155.104, 74.125.155.99, 74.125.155.105
Aliases: www.google.com
If your computer does not have a working Internet connection, it cannot "talk" to the DNS-server.
If you spell the name incorrectly, the DNS-server will report "cannot give you an IP-address".
Contact your Internet Service Provider, to trouble-shoot your Internet connection.
Or, check for a computer-virus on your computer, which could be blocking your attempts to "talk" to the DNS server.
Jul 30, 2010 | Google Chrome
Keeps stopping says cannot connect to netflix been having trouble with this
You do need an active internet connection connected to the TV and a NetFlix account to connect to NetFlix.
To setup an NetFlix account, you have to do that from your computer.
Some of the LG broadband TV's that had the same problem required a new main board. This should be a warranty issue and no cost to you for an in home repair.
I suggest you call LG for service on the TV. When you call be sure to tell them you are not with the TV. They will have you on the phone trying to trouble shoot the issue---could take almost 30 minutes. Be sure to have the complete model number (example 42LC2D UA.UASLLJR) and the complete s/r number (example 912KMN003408) before you call LG for service.
LG service number is 800-243-0000.
Good luck and I hope I have helped you.
Jun 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
