Question about Lexmark X7350 All-In-One InkJet Printer
USB cable The USB port that came with the computer does not fit,I thought this was compatible with all computers I have the all in one series X7350
  • loretta1600 Feb 22, 2008
    thanks for trying, there was a defect and had to be returned
    Genius:
  • 3,587 Answers
That's really and truly weird. Which end of the cable are you having trouble with. For this printer, the end that fits into the back of the printer, is more square, than long. The other end is the USB side. Do I have this correct, regarding the cable?
Posted on Feb 16, 2008
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Compatible charging cables for phillips go gear hdd1630/17
Apr 10, 2013 | Philips HDD1630 MP3 Player
Where does it plug in to pc
Your printer must have a USB cable like this one (some printer come without one so you need to buy it):
The square connection on the USB cable goes into this port on the printer:
mariolands_35.jpg And the other bit goest into the USB port on the computer:
Feb 24, 2011 | Lexmark X7350 InkJet Printer
My window 7 laptop do not let me install my lexmark 5470 printer even though I have the driver.
X7350 or X5470 ????
You need to first Uninstall your current printer driver.
Disconnect the USB cable from your printer.
Locate the Start / Programs / Lexmark XXXX Series / Tools / Uninstall Lexmark XXXX Series shortcut.
To start the Uninstall procedure click on the Yes button.
Please be patient and let the operation complete.
As indicated on the last screen, restart the computer by clicking Ok.
For many Lexmark products the Vista driver will work in Windows 7; the Vista driver for your printer is compatible with both the X5470 and the X7350.
If you need to download a driver try here:
X7350
V5470
Trust this is helpful. Please vote.
Dec 28, 2010 | Lexmark X7350 All-In-One Printer
Have old compaq Deskpro EN ENS815EC733 M1BU
I would buy a cheap usb card to fit into a pci slot on the old computer.
Otherwise you would need a serial cable (if your laptop has a serial port) if not it would be a serial to usb plus the software to transfer, i would say far too much trouble.
A usb card is a couple £/$
http://www.google.co.uk/products/catalog?hl=en&q=pci+usb+port+card&um=1&ie=UTF-8&cid=13689229979239224585&ei=5RBCTMCBCIyOjAfu8eUV&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDAQ8wIwAg#
Jul 17, 2010 | Compaq Deskpro EN FC 6450+ Model 10000...
I just cleaned my computer and i have a leximark 7300 series but lost the cg how can i reinstall my printer
There are Lexmark X7350 drivers available for download in the Lexmark website. But I recommend not to plug the printer to your computer yet. Download the driver first. Just click on this link: http://bit.ly/9zceAX. Choose the correct driver compatible with your computer's operating system. Then download and install. Follow the instructions on the software. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 27, 2010 | Lexmark X7350 All-In-One Printer
Don't know where i plug in my printer
I think you are new with the PC or Printers, if not, I am sorry to underestimate you, not actually, Well, I was just trying make you concentrate, This printer is to be connected to the PC via USB port using USB cable, here's the pic representation : usb-printer.gif The Flat terminal is to be connected to the PC and the Smaller terminal is to be connected to the Printer. Don't worry, It fits with the corresponding ports. printer-usb-port.jpg USB port on the printer looks similar with the above shown image. 67411-usb.jpg You have to connect in a similar way as shown above to the PC.. Good luck...
May 10, 2010 | E-Machines eMachines Desktop PC
USB cables
make sure you plug the small plug on your usb cable into your camera...easy..
the big plug on your usb cable must be plugged into your usb port on your computer. It can only fit in one way and not upside down. It will also fit into your network port, but this not correct port. If your usb plug fits into the port the right way up, and upside down, then it is the wrong port. If your computer is old, then it may not have a usb port.
Oct 08, 2008 | Cameras
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Lexmark X7350 All-In-One InkJet Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
