JVC HD-ILA Projection TV
When the power button is pressed I could hear the fan for 30 seconds then it cuts off and The Power LED and Lamp LED are blinking rapidly simultaneously with a blank dark screen.
  • 552 Answers
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
• It may be a malfunction that the fan is locked or the temperature has increased.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
The LAMP LED
continues blinking
• It may be a malfunction of the internal electrical circuits
Posted on Feb 16, 2008
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
JVC HD-56FN97 Alternating Power LED/Lamp LED
check the supply voltage if it is working in the ballast board, if this is a new lamp you must need to reset the lamp hour.
Aug 28, 2012 | JVC HD-56FN97 56" Television
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Where is the projection lamp located in the jvc HD-70GC78?
hi there, I'm sure you can find it at the back casing fronting the screen. It has this box casing and you can see a glass prism. I also insert an image of JVC lamp. hope this help, please rate and vote
Mar 20, 2011 | JVC HD-70GC78 D-ILA TV
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
JVc hd ila both led blinkin fast. Blck screen. There was no mesage . how to trouble shoot
your lamp is burned out, buy a new one online and replace according to the instuctions sent with new lamp. this a cheap and easy fix-dont believe anyone that tells you different-they are usually people that work in the tv repair industry and want everyone to think they belong at NASA!!!
Dec 04, 2009 | JVC HD-52Z575 52" Rear Projection...
Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
Nov 22, 2008 | Televison & Video
Televison & Video Logo
868 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
